07-18-2010, 03:56 PM
2010 27' FB International
Miami
Installing a composting toilet
I found a few threads discussing composting toilets but very little about the actual installation. I would appreciate some input/answers on the subject (please no pros/cons of composting toilets as it has been covered in other threads).
I purchased a Nature's Head composting toilet. It is bigger than the factory toilet and needs tilting clearance for maintenance and side clearance for the cranking. It fits in my bathroom but might not in smaller units.
The 12v wire for the fan is not fun to run but I found a route and think I can manage.
Now, my real issue is the venting. On the side of the unit (either one you pick), a venting tube comes out and needs to be connected to a vent line. I initially thought of hooking it up to the bathroom exhaust fan but it is a ceiling mount vent skylight type so not possible. I also tried to locate the gray water tank vent and T to it but can't reach it without taking out cabinets/walls.
I am now thinking of just dropping the venting tube of the toilet through a hole in the floor into the black water tank as it won't be used, seal it and let it use the black water tank vent tube. Is that an acceptable solution?
Cheers
07-19-2010, 02:56 PM
Miami
I didn't like the idea after all and ended up removing some wall partitions to access the riser pipe of the black water tank. I put a 1-1/2" T and drilled a 2" in the partition et voila!
A much cleaner job and I get to remove my black water tank to install another fresh water tank.
05-09-2011, 07:40 PM
1973 25' Tradewind
Burnsville
, North Carolina
We would lime to install a compost model. repot back in after a few uses.
Ann - The Constructor's scribe.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
07-18-2011, 11:47 AM
1976 31' Sovereign
Sandpoint
, Idaho
Composter in my total renovation
Hi there,
I'm in the midst of a total shell-off restoration project on a 31' AS. I'm looking for feedback from anyone who has installed and used a composting toilet in their Airstream before I go that route. I've had a Sunmar composting toilet in a cabin I built and it worked great so I'm not afraid of including one... but still would like to know how your installation went and if you still like the idea.
Pete
07-18-2011, 01:40 PM
Maniacal Engineer
Lopez Island
We have a Nature's Head in the Tin Pickle. It works; we've not used it much for solid waste but the liquid waste have been emptied many times. Easy to install (plumbed our vent into the former black water tank vent) and readily removable for maintenance, access, etc. It's basically there to avoid nighttime/early morning runs to the privy (port-a-potties at Burning Man).
It is strong and well-made, and allowed us to deep-six the old (non-working) toilet, black water tank (w/ stuck valves, rusted fitting, etc), etc.
- Bart
07-19-2011, 07:10 AM
1976 31' Sovereign
Sandpoint
, Idaho
Hello Bart and thanks for the quick reply. If I may ask one follow-up question... you said "liquid wastes have been emptied many times..." Are you saying that evaporation wasn't sufficient to handle the liquid waste? Or... are you saying you or your guests were emptied of liquid wastes...? :-)
Just want to be sure before I order one. I'll be glad to get rid of all the extra plumbing when I rebuild.
Peter
07-19-2011, 10:14 AM
Miami
Hi Peter. The Nature's head stores liquid and solid waste in two separate compartments. The liquid waste needs to be emptied often depending on the amount of users. We are four and I empty every two to three days. The solid waste is the composting compartment and should/mustn't receive any liquid waste. It needs emptying every month, again for four users. The longer you keep it the better. I personally like the system a lot and happy to have an empty black water tank.
I was even considering replacing the existing black water tank with a fresh water tank to increase the capacity while boon docking.
07-19-2011, 11:31 AM
1971 27' Overlander
2004 25' Safari
Jourdanton
We did a temporary installation of a NH composting toilet in our 57 Caravanner for the trip from Alaska to bring her home. It works well, but you must allow a bit more room for it than for a conventional toilet. We still have not settled on a floor plan When we do our remodel, but serious consideration has to be given to the space it requires. Installation instructions can be found on the NH website.
Paula
11-05-2011, 02:39 PM
1980 20' Caravelle
Ogden
, Utah
Could anybody who has installed or used a Nature's Head composting toilet give me an idea of the workable dimensions for a little room that would house just the toilet? I am thinking seriously of installing one of these in my 20' Caravelle and would like to have enough room for it to be functional without any space wasted.
I am starting the interior from scratch so I don't have any obstacles other than the wheel wells which are seriously getting in the way of every idea that I have.
I have looked at the web site and found those dimensions, but my questions are: how much clearance do you need in front of it to sit down in a little room with the door closed? How wide would a room really need to be for a normal sized person to use the toilet if that was the only function of that room?
Thanks for all the insights on this thread. I am inspired by the idea of a composting toilet. My parents have a Sunmar in their cabin which has trouble when too many people use it since it does not separate wastes, but it works great when there are only a few users and the moisture levels stay low. The separate urine container is genius I think. Now I just need to figure out where it can go?
Tim
01-11-2012, 05:52 PM
1977 31' Sovereign
San Francisco
I'm curious about the Nature's Head. The only thing I'm not crazy about is the frequency of having to empty the liquid jug, since I'll be full-timing. Has anyone investigated the possibility of keeping the black tank installed and routing the liquids into it?
01-11-2012, 07:18 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Since the late 70s, the Marine Industry has developed several toilet waste systems. It is far more difficult for boats to find dumps, than for RVs. Some of these systems emit almost drinkable water and a container of solid waste, easily handled and disposed. They are usually expensive, and do use lots of electric power do to their work. Most "heads" in boats are at or below the water line, so when using the holding tank method, a good pump is required and must "suck" from the boat and "push" to a big tank located some distance away on shore where it can be reached by a "Big Red" truck.
I think if they were the "hot set-up" for RVs, the industry would have gone to them a long time ago.
The flush toilet and holding tank system works very well for RVs. Dumps are not usually hard to find, and we have gravity on our side when it comes to dump time.
For the money spent, and chance of failure, I think I still prefer the dump into the holding tank and dump the holding tank system most of us still use.
Complex sewage systems can lead to expensive equipment, very expensive repair, and in the event of failure, you're done camping.
Just my thoughts.
01-12-2012, 09:02 AM
1977 31' Sovereign
San Francisco
Thanks for that Amazon link. I think the idea of replacing the black tank with another grey tank is pretty solid. I emailed Larry (who runs Nature's Head) and he said that someone has definitely modded the Nature's Head to dump into the existing black tank and he's going to send me photos. Exciting.
11-22-2015, 04:42 AM
LABTOPIA
1958 22' Caravanner
Atlanta
, Georgia
tim,
I measured my space which i would feel is the minimum comfortable use-
3ft deep x 2ft4in wide. also mine is elevated on a 4x4+plywood riser to clear the wheelwell and make it 'adult height' comfortable. mine is installed in my shower (its designed so it can get wet without damage.) i drilled a hole in the bottom corner of the shower to vent out the side and covered the outside hole with a small atwood clamshell cover, very inconspicuous and looks like it should be there. be sure to put screening material on the intake and output of the toilet as well as on the output of the hose to the vent bulkhead. i got some gnats in there and were hard to get rid of. after using screen window material to keep them out of it no problem.
MY NATURES HEAD INSTALL
dave
12-03-2015, 09:27 PM
Denver
Hi there,
I know your posts were several years ago but this is exactly what I was hoping to do. We full-time and are currently in Colorado, last winter were in Missouri. Frozen tanks are not fun but a necessary evil of not being able to head south. I think the Nature's Head would be excellent as we could just leave the gray tank open and not worry about dumping the black. I would like to combine the black and gray tanks into two gray tanks and divert the urine to them as you suggested. Did you end up going ahead with this installation and do you have any of the pics that were sent to you from Nature's Head?
Thanks!
Tiffany
2005 30 Safari Bunkhouse
I'm restless. Things are calling me away. My hair is being pulled by the stars again. -Anais Nin
12-04-2015, 05:16 AM
Mantua
, Ohio
Frozen tanks are not a necessary evil if you winterize properly. There have been threads on winterizing and still being Able to use the trailer. Composting toilets may work but the gray tanks will have to be winterized as well as the fresh water system.
02-04-2016, 12:44 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Originally Posted by tifspiff9
Hi there,
Thanks!
Tiffany
Tiffany, check out this post here: http://www.airforums.com/forums/f382...ll-146271.html
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
10-07-2016, 02:05 PM
2005 31' Classic
Garner,
, North Carolina
good info here for sure..
now for another question on the install..
I was seeing where someone was asking about piping the urine into the gray or black tank and was wondering if that was a good or bad thing.. seem dulation would take care of any issues with that.
On my 2005 classic there is no vent pipe to tap into so I was wondering if it was possible to vent into the sink drain line up high just under the bowl, and also diverting the urine there as well.. would that need a p trap(get it "Pee" trap) or would the existing p trap be fine.
thought??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
04-03-2017, 08:48 PM
2005 31' Classic
Garner,
, North Carolina
so to follow up a bit it now time to get the natures head installed.
This weekend after dewinterizing the unit, I removed or tried to remove the old RV toilet. right off the bat the nuts on the bolts holding the unit to floor flange were a bit@h with LOT of corrosion.. after spraying with some rust buster product and holding screw with pliers it still wouldn't budge.
Had to get chisel and bust the bottom of toilet to get it off.. not a big deal but was hoping to clean up and sell the old part.
so next i unscrew the screws on floor flange and unscrew the floor flange.
My plan is to get a 3" screw on cap, put a piece of 3/4" plywood on floor on top of cap, cut slot in plywood and figure out how to get hose on liquid part of NH and route into cap through hole I drill and seal so liquid goes into black tank, which can now be combined with gray tank to increase capacity.
there is a clean out past the elbow in gray line from sink to tank. I got a 1 1/2" barb, screwed in the the fitting and was going to fit the vent hose on this. see picture.
still working on project and will get more pictures.
Carl, Raleigh NC
