Old 03-09-2004, 06:13 PM   #1
tin can luv's Avatar
1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
I Want a Round ?Aluminum? Sink
In the newer A/S I have seen pictures of the round sinks, metal of some sort. Where can I get one? I want to install one in the Overlander, but haven't found them in any parts lists.
Anyone?....Anyone?....
THanks
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 03-09-2004, 06:16 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Round Stainless sinks are $ 40.00 at Home Depot. They have 2 sizes. Look for the wet bar sink.
Also, try www.rvpartsoutlet.com
They have them as well for a good price.
If you want a bigger one for the kitchen area, with a large size drain, then a better appliance/plumbing supply will surely be able to get one for you.
Uwe
www.area63productions.com
Old 03-09-2004, 06:17 PM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
They're stainless steel. You can probably find the part number in the on-line parts manuals (PDF files) at the Airstream site. Look for the manual that has the International CCD.
Maurice
Old 03-09-2004, 06:19 PM   #4
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Ok, here is a link:
https://www.rvpartsoutlet.com/newsto...0A6678CC71BD60
Better use the navigation on their page, not the browser bar. It will throw you out otherwise.
Good Luck
Uwe
Old 03-09-2004, 06:41 PM   #5
1968 22' Safari
1976 27' Overlander
Images: 82
Perfect! Thanks guys!!!!
Ron
Old 03-09-2004, 06:46 PM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
...or you could use a stainless steel salad mixing bowl. I plan on putting one in my bathroom whenever i build a cabinet for it. They come in a bunch of different sizes.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-09-2004, 06:56 PM   #7
1968 22' Safari
1976 27' Overlander
Images: 82
Now that's what I call using your crative imagination!!!
Old 03-09-2004, 07:21 PM   #8
try
http://www.scandvik.com/
Its a marine supply
They are a great place for sinks and faucets and all sorts of stuff that you cant find. Its seems that all the nice metal stuff is for houses and if you go to an RV place you can find the smaller stuff you want , but its usually plastic.... Scanvik has a lot of nice options in smaller sizes. good lighting sleection too
-Andrew
amfab is offline   Reply With Quote
Old 03-09-2004, 07:43 PM   #9
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I just went through the owners manual and documents for our 28' International CCD. It has the round sink in the kitchen. The manufacturer is Kindred. Their web site is www.kindred-sinkware.com
The exact model is not specified for our sink but I'll try to get it when I go to the storage facility.
Good luck,
Dennis
cosmotini is offline   Reply With Quote
Old 03-11-2004, 06:21 AM   #10
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I was interested in these cool sinks as well, so I took a picture of an unopened box while visiting the factory. Hopefully this helps in your quest.
Name:	kindred round sink.jpg
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 03-11-2004, 06:32 AM   #11
mandolindave's Avatar
I just replaced my beautiful avacado double sink with
a stainless steel single sink. Besides aestetics ( sp ?)
I can now fit pots and pans in the sink for washing.
If I ever need an extra sink for soapy water, I'll just use
a tupperware tub.( which I can use for a couple of other
chores as well ) Mandolin Dave
mandolindave is offline   Reply With Quote
Old 03-11-2004, 06:48 AM   #12
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
To take DPeak's post a step further.....
http://search.yahoo.com/search?fr=fp...ss+steel+sinks
That was a great pic and had all the info needed to do a search. Afterward I also noticed that even the part number is on the box. Should be an easy thing to get.........
Great pic DPeakMD!
Old 03-11-2004, 06:52 AM   #13
Aluminut
2004 25' Safari
. , Illinois
Ok, I had to look. The 18/80L can be found here, but the pic looks a bit different than the one in my coach. It sells for about $193.00:
http://www1.shopping.com/xKW-bar_sin...040480/GS.html
Scroll about 1/2 way down the page and you'll see the 18/80L.
Old 03-11-2004, 07:45 PM   #14
1968 22' Safari
1976 27' Overlander
Images: 82
Silvertwinkie, that's great! I'll read on, ( you know, just looked at the picture LOL)
I stopped at Lowes to check out their selection too. Whatever works, ya know.
No, sorry, whatever's cheapest.
Ron
