Old 06-26-2011, 12:39 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
I am having problems pulling thetford toilet
are there bolts in the back that i cannot see? i have one by the pedal off and that is it. i couldnt find what i was looking for in my 73 manual.
Thanks, Ben
bennyg is offline   Reply With Quote
Old 06-26-2011, 12:47 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Yes, there's on in the back. If you lift the lid, you can see a round plug on top. If you remove the plug you can insert a socket on a long extension and reach the back one. At least that's how it was on mine, but it was the taller model. The lid looks the same though.
Vaughan
Old 06-26-2011, 01:59 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you're really flexible (contortion artist), you can reach behind the toilet to get the second bolt. They're lots of fun either way.
Old 06-26-2011, 02:03 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
mirror helps after disconnecting water line to give line of sight
1978 ambassador toilet leak mohrjr Sinks, Showers & Toilets 4 05-20-2011 09:38 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Thetford Aria Deluxe II Bluto Sinks, Showers & Toilets 7 01-18-2011 11:44 PM
