Old 01-30-2015, 08:15 PM   #1
richw46's Avatar
Lexington , Kentucky
How to tighten the vanity faucet
The vanity hot water handle is loose. Cold water is just fine, nice and tight, but the hot water is flopping and rattling. I don't see any hex key along the outside, how the heck do you tighten the handle on a 2006 Safari vanity?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-30-2015, 08:58 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
A pic would help. If it has an identifying letter on top. See if it pops off. Many. Brands have a screw inside under the letter "H" or "C".
Old 01-31-2015, 10:02 AM   #3
richw46's Avatar
I figured it out. Other faucets, you are correct, the H or C pops out and the screw is underneath but this one is different. The other day the kitchen faucet, single handle, came loose and wouldn't shut off. I had to push down on the handle to turn it off. Then I noticed the base was loose so I started turning it and sure enough, it tightened down. Swinging the faucet must loosen the faucet.
I went back to the vanity faucet and started turning the band at the base of the faucet. It was tight but turning eventually allowed the handle to come off. On the inside was a phillips head screw. I tightened it and replaced the faucet handle by screwing it on; voila!
Posting pics for future reference.
ID:	231442   Click image for larger version
Name:	Bath Faucet.jpg
-Rich
Rich & Yvonne
2004 4Runner SE
Old 01-31-2015, 10:33 AM   #4
mandolindave's Avatar
There is a lesson here….
The first time you do something is the most difficult. It is similar to reinventing the wheel. Often, tasks are simple if you allow yourself to focus a bit.
BUT…Sometimes there is a trick, or a sequence, or something you can't see.
In addition to this forum, Youtube videos have helped me fix a lot of stuff
The tricky thing is determining what you can and can not fix.
mandolindave is offline   Reply With Quote
Old 01-31-2015, 11:55 PM   #5
2005 19' Safari
GLENDALE , AZ
I have the same problems with our faucets, so great timing on this post.
Also, thanks for the helpful photos!
Over tighten lug nuts Pepsi Wheels, Hubs & Bearings 3 10-27-2012 09:47 AM
Towing a car with a dolly... tighten those straps and check them! Skater General Motorhome Topics 21 02-26-2011 11:02 AM
Does anyone know how I tighten this screw on the screen door holding clip? MikeDT Doors & Locks 9 04-18-2010 10:15 AM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 04:50 PM
Tighten old vs all new rivets lwebb Ribs, Skins & Rivets 28 02-11-2004 03:38 PM
