Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-07-2015, 09:22 PM   #1
The Rambler's Avatar
1964 26' Overlander
Ingleside , Texas
How to remove tub/shower/sink/toilet unit in 64 Overlander
Any good advise out there on removing the bathroom unit (tub, shower, sink and toilet) in a 64 Overlander? This thing is put together like a jigsaw puzzle. Have removed all visible screws and rivets but the sink is still securely attached to the back wall of the bathroom.
The Rambler is offline   Reply With Quote
Old 07-08-2015, 02:07 PM   #2
1979 23' Safari
Wayland , New York
Take it slowly. Lots of pics to remember how to put it back together.
Use a slim putty knife to slide between the sink and wall to check for fasteners. Sometimes even after drilling rivet head off the shaft still keeps a bite on what it was holding. Silicone or similar may be holding it as well.
Shower drain pipe may have to be cut underneath the floor. Mine was solvent welded to the tail piece so that was the only way it was coming out.
Old 07-08-2015, 06:52 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
If I recall correctly there were "hidden rivets" behind the sink. I think this is where Airstream may have assembled the sink to the tub before attaching to the wall. My sink faucet was badly corroded and would not come apart. I cut the ABS shower drain pipe and pulled the tub out with trap attached. I had the belly pans down first. My toilet was badly corroded. I had to cut the bolts from the flange, cut the copper piping, and lift it out. I had removed the console already.
Mine is a 66, and may be different than your 64. I know the 65s and 66s are similar.
David
Name:	1311 Sink ABS Shower Valve.jpg
Old 07-13-2015, 08:53 PM   #4
1964 26' Overlander
Ingleside , Texas
Thank you for your input. We are learning the value of the Forum as a resource! Sure enough there were some elusive rivets holding the durned thing in, but we were successful in removing it without damaging any of the unit. The bigger challenge was getting it out the door of the A/S! A little squeezing and a lot of Norwegian ingenuity got it done.
Old 07-14-2015, 06:52 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
We have a lot of that Norwegian stuff here in Minnesota too. My favorite is "goot n tite" for the torque spec on trailer wheel lug nuts.
David
Painting shower tub and sink humboldtair Cabinets, Counter Tops & Furnishings 17 10-02-2021 03:14 PM
Need shower/sink/cabinet unit for 29' Ambassador Twin Center Bath! Freemason Cabinets, Counter Tops & Furnishings 0 08-28-2013 08:46 AM
repairing '65 Safari Tub/Sink/Shower chris clark Sinks, Showers & Toilets 1 03-03-2007 10:37 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
