Old 07-15-2009, 08:45 PM   #15
Silverslug75's Avatar
1973 31' Sovereign
Vashon , Washington
So, this is where this is at now. There is a patch of plywood on the floor (with the fake vinyl parquet tiles) which it is safe to assume was put there to cover rot, don't you think? It seems solid now. Can I leave it there? I would HATE to have to rip out and replace the entire floor. Or is it really all that hard to do? What we have left is just a hole to the tank underneath as far as I can tell. Also here are photos of the flange I removed. Yuck!
Name:	airstream rm2 013.jpg
ID:	83974   Click image for larger version
Name:	airstream rm2 015.jpg
Name:	airstream rm2 016.jpg
Silverslug75 is offline   Reply With Quote
Old 07-15-2009, 08:57 PM   #16
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Sorry, but you need to fix the floor. If you don't and it's rotten around the edge where the floor goes under the shell. You will get rear end separation. Very Bad.
You can just patch the bit that is rotten as long as you cut the flooring out over frame members. then drill holes through and put some screws in them...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-04-2010, 07:30 AM   #17
1978 31' Excella 500
SOUTH ANHERST , Ohio
HI ALL I AM A NEW TO THE AIRSTREAM FAMILY AND HAVE NEVER DID THIS BEFORE AND HAVE JUST PURCHASED A 1975 ARGOSY AND WOULD LIKE TO DO ONE OF THE FOLLOWING
REPLACE THE TOILT , CAN A NEW ONE BE PURCHASE AND IF SO WERE??
OR IF NOT CAN A LID FOR THE TOILT BE PURCHASED AND WERE ?
AND MY LAST QUESTION BEING OF 1975 JUST HOW HARD WOULD IT BE TO REMOVE AND REPLACE????
Thanks All George
Gosman is offline   Reply With Quote
Old 06-05-2010, 12:08 AM   #18
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Dennis: Good suggestion, my toilet is a bit "wobbly" - your fix should make it rock solid.
Thanks!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 07-28-2014, 06:13 PM   #19
New to the fourm ,
I have be gathering info on the removal and replacement of my 1975 Argosy Airstream toilet to replace the valve in the back that is leaking .
So just so I understand ,there is a bolt with a 1/2 inch nut that needs to be removed in the front by the step pedal and I have removed the cap on the left rear and I will need a 1/2 with a extention to remove the nut I can not see , should I have a deep scocket with magnetic tip????????
thanks all
Old 07-28-2014, 06:41 PM   #20
kootenayken's Avatar
1976 Argosy 22
cranbrook , British Columbia
Gosman, I have a 76 Argosy and was able to reach in and slip a ratcheting 1/2 wrench on to that back nut. A set of ratcheting wrenches are indispensable for those hard to reach places, once on the nut you do not have to keep taking it on and off the nut. Just rotate in the direction needed and pull back till loose.
kootenayken is offline   Reply With Quote
Old 07-29-2014, 06:39 AM   #21
Kootenayken
Thank you so much for the info on taking the nut off in the rear , question is it more of a feeling for the nut as you have to put the extention with the 1/2/ down through the hole ???? or using a wrench can one reach from the back ? do not understand completely ???
I do know if I can see it and put a ratcheting wrench on it that would really help . could you please explain did you take off inserting through the left rear hole in the toilet the rear nut ???????
Old 07-29-2014, 07:32 AM   #22
1976 Argosy 22
I was able to see the nut through the hole in the toilet. The socket on an extension would not get down to the nut because of the angle. So I was able to reach around from the back and slip a wrench on to the nut to loosen it, then spin it off with my fingers. When you go to put the toilet back you have to go through the same process to get the nut back on the Tbolt. A lot of feeling around and nimble fingers to get the nut started on that back bolt.
Old 07-29-2014, 04:58 PM   #23
kootenayken
Thank you I am going to give it a try , thanks again.
George
Old 07-31-2014, 01:57 PM   #24
I DID get the toilet off but the valve is a older style not the one I ordered and rusted on bad may brake the toilet I tried to remove the 2 screws but they are rusted and no heads any more
I Went to our local rv store and purchased a new toilet and in the 1975 argosy my old one was low profile 11 inches total high with the back rest .
the new one is 12-13 inches high and the toilet lid can not go under back rest molded piece any ideas ????????need help . Would like to purchase one that will fit a 1975 Argosy? low profile
I called Vintage Airstream Sales and they do not have any thing that low ,
RV Shop may have some thing lower but the flange in the floor would have to be changed not sure if that is a option with the black tank ?????????
Need help ASAP
THANKS ALL
pss Kootenayken good instructions on taking toilet out .
last question
My black tank I have noticed in middle rear has a steady drip when tank is full and not released any ideas.
thanks a again I know I have asked a lot of questions but have never had these issues
toilet
How to Remove Toilet Flange from Waste Tank? monocoque Waste Systems, Tanks & Totes 15 06-10-2013 06:41 PM
How to Remove Toilet in 78 Ambassador Mainstream Plumbing - Systems & Fixtures 5 12-13-2008 05:38 AM
Remove 72 Sovereign Toilet acanthus Sinks, Showers & Toilets 6 03-23-2008 06:17 PM
Remove toilet to to put in new tile dmadam Sinks, Showers & Toilets 2 11-02-2004 03:30 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
