Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-06-2008, 05:31 PM   #1
azfiredog300's Avatar
Surprise , Arizona
How to remove/repair leaking B/R faucet
I have a couple problems here. First, the tambour cabinet is stuck in the closed position so getting to the faucet is a real challenge. Second, I think the faucet will need replaced rather than repaired, any idea's where I can get a replacement? Will the ones at the local RV store fit? Will I have to remove the entire sink assembly to get to it or is there an easy way to unstick the tambour?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 07-06-2008, 05:55 PM   #2
. , At Large
Is the bathroom in the back? Do you have the valve access hatch in the rear? If so, it's really easy to get to, from inside the hatch. Unscrew the water lines, unscrew the mounting nuts, and lift the faucet off from inside the trailer.
Old 07-06-2008, 06:09 PM   #3
Surprise , Arizona
It is a rear bathroom but there is no access from a rear hatch, It appears that the only access is from the stuck tambour door.
Jerry C.
WBCCI #13317
AIR #25664
Old 07-06-2008, 07:39 PM   #4
. , At Large
Has the tambour ever worked? We had one that wouldn't open fully, and I had to disassemble the thing to get at the hair pins/clothespins/"stuff" the PO's left in the cabinet.
Old 07-06-2008, 07:52 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Early 70's had that big tambour under the corner sink. My 75 has a different arrangement for which I am grateful.
I had another door that would barely move and was getting worse. I sprayed the tracks with silicone and kept working it, pulling it (and lifting) into the roller area and not pushing it by the handle. Once I could get it open enough to get my hand inside I sprayed the roller grove area with liberal amounts of silicone as well.
Richard
Old 07-06-2008, 09:06 PM   #6
Surprise , Arizona
Yes it is the large tambour door. I can't even seem to get it to move at all. Guess I wiil have to work it more, I'll try spray as well. and it has not worked since I have had it.
Jerry C.
WBCCI #13317
AIR #25664
Old 10-25-2008, 11:59 PM   #7
1973 31' Excella 500
Morristown , Tennessee
I agree with the lubrication mentioned. My first trailer had this problem and I applied silicone spray daily for about five to six days and slowly worked the tambour loose but also not just using the handle. Once free, I cleaned the track and used some pure Ivory soap (dry) for lube and then wiped it out. It never had that problem again.
Just keep working on it and it will become part of the energy that makes the trailer yours.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Kitchen Faucet Repair carnegie1935 Fresh Water Systems 14 01-17-2009 07:31 PM
Bathroom faucet repair / replacement jesus mike Sinks, Showers & Toilets 7 06-08-2007 10:36 PM
Kitchen Faucet Repair hhessig Sinks, Showers & Toilets 2 05-23-2006 03:16 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
