How to remove/repair leaking B/R faucet
I have a couple problems here. First, the tambour cabinet is stuck in the closed position so getting to the faucet is a real challenge. Second, I think the faucet will need replaced rather than repaired, any idea's where I can get a replacement? Will the ones at the local RV store fit? Will I have to remove the entire sink assembly to get to it or is there an easy way to unstick the tambour?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
