Old 06-10-2009, 11:24 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
How do you replace 72 Tradewind sink?
I will be taking out the cracked sink in my Tradewind and replacing with an identical unit. Anybody with a step by step procedure? Drill out rivets? If so what rivets/gun do I need when I put the new unit back in? And what to make sure NOT to do to screw things up?
RichHog is offline   Reply With Quote
Old 06-10-2009, 11:27 PM   #2
azfiredog300's Avatar
Surprise , Arizona
Kitchen sink or bathroom sink?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 06-11-2009, 12:20 AM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bathroom Sink in Tradewind
it was the Lavette for the wet bath that I'll be taking out the L shaped one
Old 06-11-2009, 03:48 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Disconnect the water and drain lines. There is a special long handle wrench that really helps. I found mine in a hardware store. Take off the trim insert nosing on top and the trim along the lower edge. drill out the rivets with a 1/8" drill. If that is too small use a 9/32". A standard rivet gun with 1/8" pop rivets will work. I would try 5/8" length rivets. While you are at it check you tambour for any needed repairs.
Are u replacing it with a new unit? Where did you get a replacement and how mucha?
Lumatic is online now   Reply With Quote
Old 06-11-2009, 07:57 AM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Sink replacement
Thanks Lumatic, I'm probably about a year behind you on all these repairs. Annette is shipping me the sink she took out of her trailer for cost of shipping $132. Hope UPS brings it in one piece. I wonder if I should take it by a fiberglass shop to get a fresh coat of gel or paint put on it before doing the install? Did you unscrew previous plumbing or cut it and reconnect?
Richard
Old 06-11-2009, 08:08 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Keep in mind the lavarette is ABS not fiberglass. I don't know if fiberglass gel coat will stick. Epoxy paint such as Tough as Tile works great.
Old 06-11-2009, 09:37 AM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If the water lines are the same as on my moen faucets at the lav,you will need to cut the 1/4 " supply lines and reconnect with 3/8 compression unions.Dave
easyride is offline   Reply With Quote
Bathroom Sink Cracked in 72 Tradewind RichHog Sinks, Showers & Toilets 15 08-11-2010 06:34 AM
1972 25' tradewind bathroom sink berickn Sinks, Showers & Toilets 2 05-25-2009 08:14 PM
Need to replace furnace in 75 tradewind flash Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-22-2009 07:15 PM
1971 Tradewind Shower/sink Mr. Johnson 1970-79 Tradewind 4 03-30-2007 03:06 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
