Meredith, You should look in the forums tab above! Select the trailers section and scroll down to your model the year. Look for photos of the bathroom in a trailer like yours! That will give you an idea just how much destuction was done to the fiberglas surrounding the toilet. Then see if you can get a member here who owns the same trailer as yours to give you all the measurements to the surround so you can determine if a local fiberglas shop can help you restore the surround to its' original design. But first... I think you need to see if an original (replacement) toilet model is available. If not, you may want to re-design the bathroom to allow a different toilet in the area and see if the sides of the surround/tub can be re-designed/repaired. It may not be an original looking bathroom but functional works too! Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
