Old 08-24-2007, 08:34 AM   #1
newbie part timer
1976 31' Sovereign
Houston , Texas
How do I access pea trap in middle shower?
I recently purchased a 1976, 31' Soveriegn; i don't own a house, but i've got my Airstream!!!
After a month of weekends repairing fresh water lines i'm down to my last issue; I've got a leak in the shower drain. Since all of the other pea traps were ruptured due to freezing i figure i've got the same problem with the shower. How do i gain access to it? I've searched the forums and found one example of pulling off the face of the shower basin where the heater vent is located. I've also seen people gain access from the under belly? Any suggestions?
Thanks in advance for you help.
Kaybob is offline   Reply With Quote
Old 08-24-2007, 09:10 AM   #2
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
In my '68 there is an access hole in the bellypan under the shower. I don't know if your year is similar?
Tanya
"If you want something done right, do it yourself!"
sequoiacoast is offline   Reply With Quote
Old 08-24-2007, 10:00 AM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Same here. Your trap probably will be different than a house one in that it may be not as deep. If so repairing any cracks in it may be an option so don't throw it away before you know if you can easily replace it.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-24-2007, 10:55 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My guess is that you will have to get to it from the bottom. My 75 TW has no access pannel on the belly pan, but one could easily be made. Measure twice, cut once!
Richard
Old 08-25-2007, 06:58 AM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
No there's a tank under it, you need to remove the panel (about 10x24) you step over to get into the shower, some have a heat vent in them, then you can see it all.
You need to remove a bunch of mouldings to get it out.
'77 Sovereign Intl 31' CB
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:13 PM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
Removing the shower stall - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 8 06-16-2002 10:35 AM
