Old 06-07-2010, 12:15 PM   #1
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Hot water in toilet?
We are getting hot water in the toilet while hooked to city water but not when using the pump. I just dont get it. I would think if we had a bad mixer in one of the other fixtures it would be that way all the time... This spring is the first time we have used the city water hookup most regularly so I dont know if this is a new problem or we just never noticed before.
I did have to replace the PaR pump with a shureflo this spring. Replacing one pump for another with miner hook up modifications nothing that would change the water to the toilet.
Any suggestions?
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 06-07-2010, 12:26 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Are you sure it`s not just the water getting hot in your supply hose to the trailer,cause it makes no sense. Dave
easyride is offline   Reply With Quote
Old 06-07-2010, 12:34 PM   #3
Elkhart , Indiana
Nope... not water hose getting hot.. We first noticed it the last weekend of March while at the NOVA rally at Jackson center (our first full hook ever) The temps outside were just above freezing. The amount of steam comming out of the toilet durring the flush was strange so I grabbed the sprayer handle and "CRAP THAT IS HOT!!" bout burnned my hand.
I dont get it either.
Mike
Have a great day!
Old 06-07-2010, 01:19 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Getting crossover, might be winterization valve open at the water heater, closed at outside letting hot get to the cold by dump line.
Old 06-07-2010, 01:30 PM   #5
Elkhart , Indiana
okay... now that you say that... I dont think there is a winterizer bypass on this one... I will look on Thursday when I go get it for the weekend... I do know the line to the toilet is just inside the cabinet next to the toilet. But I dont recall a Bypass kit... I am sure if it is there I did not use it last fall.
And another thing while I am thinking about it... All the faucets are backwards while on city water.... This is just strange
Thanks ... keep the ideas flowing I would like to have a grasp on this so I can figure it out on Thursday
Mike
Have a great day!
Old 06-07-2010, 01:42 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Sounds like the city water hookup is into the hot water pipe instead of the cold line.
Chris
Old 06-07-2010, 01:52 PM   #7
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Be very careful if you have to do a 'courtesy flush'
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 06-07-2010, 01:56 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Mine was just as Minno stated. The city water inlet was connected to a hot water line. Everything was great when using the watr pump, but everything was reversed when connected to city water. One cut and a few PEX fittings later it was good again.
Richard
Old 06-07-2010, 05:21 PM   #9
Elkhart , Indiana
Thanks for the thoughts... I will look into this on Thursday. ( I hope it is not rainning)
Mike
Have a great day!
No water in hot water line timkim Fresh Water Systems 6 12-13-2008 05:26 PM
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 02:34 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
