Old 04-30-2014, 01:16 PM   #1
Happy Trails
1987 32' Excella
Zavalla , Texas
hot water flow in shower tapers off
I turn on my shower and the water comes out nicely. But in about a minute, the hot water flow becomes a trickle. The water coming out at the shower hose connector is hot. Anyone else have this problem? The hot water doesn't do this at either of my sinks.
k5uuu is offline   Reply With Quote
Old 04-30-2014, 02:24 PM   #2
aftermath's Avatar
Spokane , Washington
Disconnect the shower head from the hose and run the hot water. If it flows freely then your shower head is probably clogged. If it doesn't, then I would take a look at the cartridge behind the shower control.
aftermath is offline   Reply With Quote
Old 04-30-2014, 02:25 PM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I kinda had a similar thing happen to us on our last trip. I had turned on the hot water tank and even the propane so the wife could take a good hot shower. We had been using it for dishes, etc. so I thought all would be OK. Wife yells out NO hot water, what did you do. I could not believe it. Figured she probably did not turn it right so I go in to show her what to do. Nope, she had it right, you could start to feel some warm water, but that's it. If you turn the handle to cold, you had good pressure, but when turned to hot, it would slow way down and barely be warm. Checked hot line going in, it was hot. Tried taking it apart, but could not really get anywhere with it so just but it back together and figured, let me try reversing the lines going in and see what happens. Well, it worked. something in the valve was sticking I guess and reversing the lines or half way taking it apart did the trick. I since have put the lines back the right way and all is good. The trailer had sat for over a year without being used, so that could of been why the valve got stuck. Hope yours is as easy to fix
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 04-30-2014, 03:27 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try removing the shower head from the hose. After removing the head see if you get good flow and temperature control through just the hose. If so the shower head is the problem.
Generally I would say dirt from the hot water heater is in the head but that would not be effected by the run duration and would effect both hot and cold flow.
2004 Excursion 4x4
Old 04-30-2014, 07:50 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'm guessing this is it, too - the sink in our B190 used to give me fits regularly with similar problems. I eventually realized that it's very sensitive to where the outlet holes in the cartridge are relative to the spout, and similar things.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
2004 Classic Limited shower valve leaks hot water when turned off? myrnaw Fresh Water Systems 1 08-02-2010 08:34 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 09:54 PM
Shower Regulator or Back Flow Valve GStephens Fresh Water Systems 19 07-08-2004 10:56 AM
