Old 04-21-2018, 06:23 PM   #1
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
Holding tank drain valves
Is it necessary to remove the belly pan to replace black and gray water valves?
jfowler218 is offline   Reply With Quote
Old 04-21-2018, 06:36 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
It depends on the trailer. Several people have, and I plan to, cut an access hole around the valves and make a cover to fill the hole when I'm done. If you can see the valves through the rod holes and are careful you can probably cut without hurting anything. But the sensor wires for the tank gauges may be in the same area. Clearly it is safer to pull the pan unless you are sure you won't hurt anything. There is already a small access hole in my pan so I plan to just enlarge it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-21-2018, 06:39 PM   #3
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
Al
Thanks for the info. Is the pan mounted using screws or rivets?
Old 04-21-2018, 06:43 PM   #4
2000 30' Excella
Toledo , Ohio
I cut a hole in mine about a 2'x2' square . did it last year used a grinder with a abrasive wheel , makes a clean cut unlike a nibbler . easy job if you don't mind laying on your back . I left the wheels on and put blocking under the tires to get enough room to work .
woodfox45 is offline   Reply With Quote
Old 04-21-2018, 06:44 PM   #5
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
Old 04-21-2018, 08:20 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I bought a set of electric shears at Harbor Freight to cut my hole. I made a cover plate from a street sign from the local recycler. Airstream should have put in an access panel in the first place, especially since in the owners manual they tell you cutting a hole and not dropping the pan is how they service the valves.
My valves are in front if the axle. I raised my jack as high as it would go. Then, I lowered the stabs as far as they would go and put blocks under them for a safety net. I had plenty of room to work.
CRH is offline   Reply With Quote
Old 04-21-2018, 08:58 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Airstream accessed the valves on my trailer by cutting a hole in the pan. I cut a hole in the one I did with the Harbor Freight nibbler. It is a thick tough piece of metal and everything falls into your face. I put the cover patch over the hole on with screws. Airstream uses rivets. All in all the job went pretty well. When you drill down there you need to be sure to have a positive stop on the drill bit.
Old 04-21-2018, 09:08 PM   #8
My 2001 Safari had a polyethylene pan. It had steel straps around it screwed into the frame with hex head bolts. My 2002 Classic has a steel pan flange bolted (presumably into the frame) with hex head bolts.
Both already had access panels cut into them. The Classic access opening is not big enough to drop the valves so I'll enlarge it.
Al
S/OS #004
Old 04-22-2018, 07:45 AM   #9
dznf0g's Avatar
Oswego , Illinois
Name:	Blkgry access.jpg
Then fabricate a galvanized access cover.
-Rich-
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 07:07 AM
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 07:45 PM
Holding tank Valves zadaschwartz Waste Systems, Tanks & Totes 19 08-03-2007 10:06 AM
Holding Tank Dump Valves odfarley 1966-68 Caravel 2 08-06-2003 11:38 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 05:01 AM
