Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-07-2007, 11:31 PM   #15
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Originally Posted by Aria
ok..another question..Does the metal flange screw into top or tank or press fit?
We could see that the leak was around the gasget area.
Thanks. The wax not working.
Aria, when I replaced my toilet, the diections called for a universal adaptor, which had a seal on it that seated on the metal ring. This was available at my local RV store. Just clean the metal ring good first, and don't bend it. I couldn't figure out how it was in there either, and almost tweaked it beyond repair messing with it.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-08-2007, 10:30 AM   #16
Aria
Aria's Avatar
Profile:  1967 20' Globetrotter
Sauquoit , New York
Thanks Dave. We are searching for a new gasket. There aren't RV stores around us. Once we locate the gasket...I think we can put the toilet back together.
Got a PM from Sharon....she said to look for other leaks. It may be MORE than the toilet. The search is on. Thanks again, Aria
Aria is offline   Reply With Quote
Old 06-08-2007, 12:32 PM   #17
Aria
Aria's Avatar
Sauquoit , New York
Thanks to all that responed to our Toilet Problem. Mel gave me Mark's RV and we ordered the gasket today. We also ordered fiberglass(they suggested) to put around the rotted wood area.
The gasket model 910(thanks to Mel) expected in 2 days. We are all set for the repair job. Tom W....I just do the typing. Husband is doing the requests, and repair. Thanks again, will give results soon ...I hope. Aria
Old 06-11-2007, 06:53 PM   #18
JK3500
Profile:  2005 22' International CCD
Woodland Park , Colorado
this site rocks!
Originally Posted by Zeppelinium
If it's fresh water, there are three top sources:
1. Frozen inlet valve. This sucker is very fragile and susceptible to freezing. Cost is ~$37 to replace.
2. Deteriorated vacuum breaker, which is a small plastic rectangular box toward the top of the toilet--the line from the valve goes there, then from there the flow goes to the bowl. There is a small float valve that has sealing material that deteriorates. This only leaks while water is flowing and if you do really short flushes you might not notice it.
3. The internal plumbing is plastic hoses held with spring clamps. These get old and loose, so almost any connection can start to leak.
Zep
we just filled up the fresh water tank last night (sanitized) for the first time after winter, ran all the faucets and noticed a leak in the toilet.
got on here to do a search and see how easy/hard it was going to be to repair and came right across this thread. picked up a new inlet valve and installed it today. no more leak! thanks for the info! jk
JK3500 is offline   Reply With Quote
Old 06-13-2007, 02:10 PM   #19
Aria
Aria's Avatar
Sauquoit , New York
Repair Toilet Leak
Thanks to you. We have a new gasket from Mark's RV (Mel). He suggested to repair with epoxy around the small section of rotten wood.
Upon examination (waiting for the epoxy stuff to dry and another coat) there is a plastic piece connected to metal and then a copper small piece of pipe.
The plastic(white) has a hairline leak. Is this the inlet valve? Husband is working. I am trying to get more info for him. Zep? Aria
Old 06-13-2007, 03:32 PM   #20
Fyrzowt
Fyrzowt's Avatar
Images: 8
Any way to post a photo of the area in question?
Old 06-13-2007, 04:11 PM   #21
Aria
Aria's Avatar
Sauquoit , New York
Dave, Husband got home. Yes this is the inlet valve. He is going to order a new one. And then??? We should be fine. Thanks so much for your responses.
It is so good to know someone on the Forum....will help. Dave, Codybear said you were an ok guy. Thanks Again. Aris
Old 06-14-2007, 02:55 PM   #22
Fyrzowt
Fyrzowt's Avatar
Images: 8
I fool someone every once in a while. Don't ruin my bad reputation.
Dave
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
