Old 09-29-2013, 10:38 AM   #1
bendavanza's Avatar
Oak Cliff , Texas
Help! Toilet flange '71 Tradewind
I'm replacing the old square toilet with a new one. The flange bolts need to be at 3 and 6 o'clock and the old ones are at 11 and 5 ish. I read that these screw on. I removed the screws and cannot get the flange to budge. Photo of flange attached.
Also the floor around the toilet flange is, of course swollen and weak. I'm going to have to replace this but it's not in the cards for the moment. I need to travel in a few days. I'm hoping the new position will help.
All help appreciated!
Thanks in advance!
Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 09-29-2013, 07:14 PM   #2
bendavanza's Avatar
Oak Cliff , Texas
I ended up taking an end mill in a drill and making my own new T slots, and a countersink to create more locations for screws. It worked out fine but the floor is still weak. Much improvement, however.
Old 09-29-2013, 08:07 PM   #3
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Had the same issue with the replacement toilet on my 1980 caravelle. I took the screws out of the flange rotated it to where the slots needed to be then drilled new holes and put the screws in. Works like a charm.
thehandyman is offline   Reply With Quote
Old 09-30-2013, 05:48 AM   #4
bendavanza's Avatar
Oak Cliff , Texas
My flange would not rotate. I tried hammering on it, too.
Old 09-30-2013, 06:32 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had a tough time getting the flange loose when I redid my Trade Wind. I made a spanner wrench "tool" out of some scrap steel. The spanner had fingers that fit into the slots on the flange 180 degrees apart and that gave me the grip I needed to apply enough torque for it to unscrew. It will unscrew but not without a fight.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-30-2013, 07:30 AM   #6
MissPearl's Avatar
1989 29' Excella
Pauline , South Carolina
I replaced on my 89 Excella. It does screw off. Quick floor reinforcement: buy a cheap: 10" saw blade; cut out hole for toilet drain and bolt holes in flange; the steel is very rigid and provides the extra support needed for old floors. Did mine 6 yrs ago. Still supporting the throne!
MissPearl is offline   Reply With Quote
Old 10-01-2013, 06:02 AM   #7
bendavanza's Avatar
Oak Cliff , Texas
Pearl:
That's a great idea. I guess I'll give that a try before I replace the floor.
I put the end if a large crescent wrench in a slot and then hit that with a hammer, no budging. I'll have to try making a wrench as suggested by 68 Twind.
For now though I think I'm "in high cotton" as they say.
Old 06-13-2014, 10:20 PM   #8
jbwillingham's Avatar
Richardson , TX
71 TW replacement toilet
So which toilet did you get as a replacement? I need a new toilet for my 71 TW.
jbwillingham is offline   Reply With Quote
Old 06-15-2014, 05:34 AM   #9
1980 24' Caravelle
I picked up a Thetford Aqua magic V low profile from PPL in Houston.
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
