Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-22-2012, 12:29 PM   #1
2011 23' FB Flying Cloud
Highlands Ranch , Colorado
Help on leaking pipe behind the wall.
I have a 16' Bambi International that leaks water inside the wall in the bedroom. It is from the shower pipe or the two on and off valves. I have caulked the inside of the shower so I now see the leak on the inside of the back wall. How do you get to the leaks and what must you remove to get there? Thanks so much for your help. Common deal? Jock
jock Barker is offline   Reply With Quote
Old 11-08-2013, 05:09 PM   #2
4RivetWannabe
2007 16' Bambi
2018 26' Flying Cloud
San Jose , California
Hi Jock,
I also have 2006 16' Bambi. I was wondering if you fixed your shower leak. I noticed a leak coming from under the wall this past weekend when my wife was using the shower. As I kneeled down outside the bathroom, I see water coming from underneath the two "shower/bathroom" walls (hallway and bedroom). The water can be seen along both walls, but not the front "door" area. I suspected water getting behind the shower pan. I had not thought of a leaky pipe or fitting.
The reason I suspected water getting behind the pan is because I noticed on the inside of the shower, the water proofing wall material along the back seam, is starting to come loose. I need to figure out what type of tack nails were used and caulk, to seal and re-attach. But maybe this is not the problem?
-Ralph
rportillo is offline   Reply With Quote
