Old 12-11-2017, 07:52 AM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
Help needed. Need picture of under sink plumbing. 1972 Sovereign.
Hi all, would love to see pics of plumbing layout under the sink, a few angles would be great.
Pics in and out of water pump and filter in particular.
Many thanks !
nickclifford is offline   Reply With Quote
Old 12-11-2017, 08:15 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What are you attempting to do? The pump is not always located under the sink, depending on the trailer.
If you are plumbing a new pump into the system it should be as follows. Line from freshwater tank, to the filter, from filter to pump input side, from pump output side it is teed into the cold water line. That connection can be anywhere you find the cold water line and is easy to work with.
I like to install an accumulator teed into the cold water line. This reduces the number of pump cycles while maintaining a near steady flow of water. Great while showering.
2004 Excursion 4x4
Old 12-11-2017, 08:44 AM   #3
1972 31' Sovereign
felton , California
you're referring to one of these assume,? sounds like a great idea ... I have on-demand hot water.
https://www.amazon.com/SHURflo-182-2.../dp/B000N9VF6Q
Old 12-11-2017, 09:02 AM   #4
HowieE's Avatar
Images: 12
Yes
Search around that is a bit pricey.
It can be had with either male or female connections
2004 Excursion 4x4
Old 12-12-2017, 06:49 PM   #5
1973 31' Sovereign
Middletown , California
I second the accumulator tank...
I highly recommend an accumulator tank, really cuts down on wear and tear on the pressure switch and often the pump doesn't even need to start if you just need a cup or two of water! It was the first thing I added to my trailer!
ijustlee is offline   Reply With Quote
sovereign
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Need picture of 310 MH specs under Visor PeterH-Airstreamer General Motorhome Topics 1 09-13-2015 04:03 PM
'69 Sovereign Picture needed of under bed storage tdoescher 1965-1969 Sovereign 9 09-04-2009 06:34 PM
Need help w/ Re-plumbing sink in '59 18'er Jephellis Plumbing - Systems & Fixtures 2 07-08-2008 08:30 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
