What are you attempting to do? The pump is not always located under the sink, depending on the trailer.
If you are plumbing a new pump into the system it should be as follows. Line from freshwater tank, to the filter, from filter to pump input side, from pump output side it is teed into the cold water line. That connection can be anywhere you find the cold water line and is easy to work with.
I like to install an accumulator teed into the cold water line. This reduces the number of pump cycles while maintaining a near steady flow of water. Great while showering.
2004 Excursion 4x4
