Old 03-28-2011, 06:47 AM   #1
Little Radio
1966 28' Ambassador
Chicago , Illinois
Grey Water Tank Flushes Toilet (to conserve fresh water)
Anybody ever rigged a grey water tank to flush the toilet? I'm considering doing so -- it's such a waste to use fresh water, isn't it?
LittleRadio is offline   Reply With Quote
Old 03-28-2011, 07:15 AM   #2
dznf0g's Avatar
Oswego , Illinois
Gray water gets to stinking after awhile. I suppose if you drop a few drops of deoderizer in the bowl after a flush, it might be OK. I would think you would need sime kind of filter to keep food chunks, etc from clogging a pump.
Old 03-28-2011, 07:16 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That sounds like an interesting concept. Other than the occasional Cheerio in the toilet, it should work. If I were to do it, I would want a valve to cut it on and off as needs dictate.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 03-28-2011, 07:18 AM   #4
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
Gray water will potentially have grease and other debris in it. This could clog up your line going from the grey tank to the toilet inlet.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-28-2011, 07:47 AM   #5
Little Radio
1966 28' Ambassador
Chicago , Illinois
Good points, all. I'm thinking I'd need a machinating pump -- like a sewage ejector pump with blades. I'd also need a filter that could be easily serviceable/reachable. Power of pump should keep line to toilet from getting clogged. Alternate switch valve for fresh water when grey water tank is empty.
Perhaps one of the maintenance items is to drop in a tablet of deodorizer into the grey tank every month or something.
I really like the idea of water conservation -- especially when you're out boondocking.
Old 03-28-2011, 08:00 AM   #6
Ottawa , ON
I have two points:
  1. I think it is too much trouble versus the potential gain. Taking "Navy" showers and not flushing every time (or in the case of #1, just a very quick flush) will allow campers to make available water last much longer. There are other ways of conserving too, lots of them are centered around kitchen wash-ups.
  2. Something about it doesn't sit right with me. I personally don't feel that it is advisable having all the extra hair, body oils, soap, peas, carrots (whether mashed up or not) sitting in the black tank. The combo of that material and the normal black tank material could promote faster growth of undesirable enzymes, odours, and so on.
Focus first on what can be done without expensive modifications to your waste systems. The "human factor" can come up with more efficient ways of saving water simply by modifying their habits, IMHO.
Do that first, THEN, if you still aren't happy with your consumption, look back over the system side of it. Modifying your system involves using more plastic, adhesives, and creates waste that might be needless in the overall picture.
Old 03-28-2011, 08:33 AM   #7
pbearsailor's Avatar
Port Hadlock , Washington
Carlos Ferguson's thread has it. Sorry it's a very long thread and I'm not sure where it is, but I know he did it. Great thread anyway, so it's a good read.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-28-2011, 08:37 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
You have a gray water tank in a '66!
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-28-2011, 10:10 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Might consider just a small, pass-thru gray tank off the bathroom sink to avoid kitchen sink debris. Just a gallon or so ought to do it. Probably have to install a filtered demand pump to move the water from the pass-thru tank to the toilet.
Lynn
WBCCI 21043
flush with grey water, grey water
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
1975 tradewinds fresh water tank elkay12 1970-79 Tradewind 2 03-25-2011 08:23 AM
Fresh Water Tank Drain Jack46 2009-2015 Flying Cloud 3 03-06-2011 01:37 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
