Old 04-06-2013, 06:03 AM   #15
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
Can I hijack this thread for a similar issue? I am with another Airstream and their grey valve handle does not seem to be connected to the valve. On my '75 Tradewind I can see the valve and connections in the bumper storage but on his '77 Tradewind there is a cover in the storage bumper that makes it so you cannot see the valve housing and pipes. Is this cover easily removed? Is there a truck to getting to this valve without popping out a ton of belly rivets?
He just bought this trailer and is on his first trip with it.
CMSmith is offline   Reply With Quote
Old 04-06-2013, 09:46 AM   #16
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Question How much oil to lubricate the valves?
Originally Posted by Bill M. View Post
sounds like the connection between the valve shaft and the T-handle has failed. find that connection and check it. usually a cotter pin holding it together. also try some veggie oil in the drain to lubricate the valve when you get it back together.
I have sticky black and gray valves. I heard about using veggie oil to lubricate the valves. How much veggie oil should I pour down the head and drain and does it make a difference what type of veggie oil you use?
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
First Trip & Grey Water Issue bike_addict Waste Systems, Tanks & Totes 173 07-30-2012 08:14 AM
Dump valve attachment to the black water tank Aktundra Sinks, Showers & Toilets 2 05-08-2012 07:15 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
New black water valve on a 1962 Bambi? female.nomad Waste Systems, Tanks & Totes 1 09-26-2011 10:28 PM
