Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-13-2009, 05:50 PM   #1
Profile:  1973 Argosy 24
Echo Bay , Ontario
Question from a newbie r: moving toilet in argosy
we have an 1973 Argosy 22. Can the toilet be moved to where the shower is. Is it at all possible. Any help would be appreciated
Calna is offline   Reply With Quote
Old 10-13-2009, 05:57 PM   #2
Profile:  1967 24' Tradewind
Redding , California
Most anything is possible with enough work and $$$. That said, you probably would need to also move the black tank so that the toilet is dumping directly into it.
SilverHoot is offline   Reply With Quote
Old 10-13-2009, 06:00 PM   #3
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I don't think I'd want to stand barefoot in that shower anymore.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-13-2009, 06:11 PM   #4
jump's Avatar
Profile:  1982 31' Excella
lubbock , Texas
Toilet Movement
Metamucil works wonders for toilet movements...
jump is offline   Reply With Quote
Old 10-13-2009, 06:19 PM   #5
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Sure you can, but it will take planning, effort and expense.
Now some questions for you:
What are your plans for the shower?
Elimination?
Wet Bath?
Relocation?
Kevin
Ohhh.. and where are my manners...Welcome by the way.
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 10-13-2009, 10:39 PM   #6
2airishuman's Avatar
Profile:
h calna
yes it is possible but WHY?
the toilet is mounted and sits directly ON the black tank, which is above the subfloor.
so MOVING it means first removing the trim/covering and then moving the tank and toilet.
and that's the easy part.
the OUTLET for the black tank goes through the subfloor and into the drain pipe.
so THAT would need to be re routed as well which means messing with stuff in the belly pan UNDER the flooring and frame.
so it's doable, but several items need to be addressed.
additionally once the fittings are messed with, IF it doesn't already leak it may start.
might as well REPLACE the 35 year old tank while doing it...$$
i think the 73 args were the beginning of gray tanks, so there is the issue of keeping or ditching the shower and plumbing.
moving the shower would be a LOT more complicated than the toilet.
there are a LOT of threads here on the famous argosy thrones and their tanks...
scan through some of the model (argosy specific) threads and you'll find pictures and plumbing shots and so on...
this thread has some SHOTS of tank options for UNDER the throne...
Custom grey and black tank fabricators/suppliers and advice!!
the good stuff on this is back in 04 or 05 postings...
is your goal to create a 'wet bath' if so there are ready made units that could be retrofitted but the under pinnings are still an issue.
one could fabricate a custom wet bath with stainless cover over the black tank, stilling in a stainless shower pan...
but THAT would be spendy.
do u canadian like to 'use' the great outdoors?
Originally Posted by Kevin245 View Post
...What are your plans for the shower....Elimination?
ahm, yes kevin, i think THAT is the word for it, or at least a moving experience.
gives a whole new meaning to this thread...
My own germs!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-15-2009, 11:52 AM   #7
Echo Bay , Ontario
thanks one and all
thank you so much for your comments - especially the funny ones! My husband told me much the same but I was really hoping there was some other answer.
Old 10-13-2009, 06:59 PM   #8
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Your toilet dumps directly (straight down) into the holding tank.
Moving the toilet is possiable but would require quite a bit of plumbing work and possibly require moving the holding tank so it is probably not feasible.
Garry
1977 Argosy oem toilet kontiki All Argosy Trailers 5 04-26-2009 05:43 PM
Broken Toilet in my '75 Argosy 1Michigander Sinks, Showers & Toilets 14 07-23-2008 11:04 PM
Argosy toilet compartment door....F.O.C. MotorSeven All Argosy Trailers 0 03-02-2007 11:00 PM
Argosy and I are moving... tkchase All Argosy Trailers 3 07-18-2006 04:54 PM
Newbie looking at an Argosy Seon Our Community 4 02-22-2003 06:20 PM
