Old 10-02-2016, 06:08 AM   #1
2003 25' Safari
London , Ontario
Flood
Important Tip: We recently returned home from a 10 day trip around our province. 1 night we were at a water/ hydro site right on the shore of Lake Huron. I woke up in the night to use the W/R and washed my hands afterwards but in the dark - I didn't see I hadn't shut the faucet off completely. As we started to wake in the morning my wife said" do you hear water dripping ?" I jumped out of bed to see the shower base full and just started running over base. Ran outside and drained off a bit of the gray water . Lucky we were just a bit nose high as the W/R is in the back so the little bit of overflow was contained .
I guess life is full of learning... Thought I would share this . We had a great trip overall !
JOZRVHLR is offline   Reply With Quote
Old 10-02-2016, 08:36 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Thanks for the sharing. It is interesting to learn how quickly the grey water tank can fill with a drip-drip-drip from the faucet.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 10-02-2016, 08:58 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
At least it was not the black tank overflowing.
MICHAEL
Old 10-02-2016, 10:53 AM   #4
2005 19' Safari
GLENDALE , AZ
Re: Waterproof Push-Button Switch Provides Momentary Water Pressure for Hand Washing
We boondock occasionally, and I added a waterproof push-button switch next to bathroom sink to allow momentary water pressure for hand washing. This is primarily used to conserve water, but it might also help avoid problems like this.
Here's the link to the push-button switch that I mounted in the wall, and wired into the water pump switch circuit:
Waterproof, Stainless Steel, Momentary Push-Button Switch (Normally OFF) - Amazon.com
Old 10-02-2016, 04:02 PM   #5
Long Island , New York
Were you on city water? [not positive about "water/hydro site"]
We always try to turn the hose bib off before retiring for the night, and use the fresh water tank for toilet water during the night. Noisier yes, but it prevents things like this, as one hears the pump come on when it shouldn't. Also prevents major problems on the rare occasion that a plumbing fitting lets go in the middle of the night. Also endeavor to turn off city water when leaving the trailer empty.
Glad the damage was limited!
Flood, pestilence, and blown fuses... SilverRanger On The Road... 7 07-17-2011 08:01 AM
Bambi Flood Jemac Winterizing, Storage, Carports & Covers 12 01-16-2005 10:19 AM
Floater - Airstream Trailer Photo From a Flood ALANSD Our Community 18 06-01-2004 01:16 PM
Flood light lens melting nickcrowhurst Lights - Interior & Exterior 5 12-24-2003 09:38 AM
An then came the flood Pahaska Our Community 50 01-06-2003 01:59 PM
