Old 10-14-2012, 03:54 PM   #1
Single Slice
2004 28' Safari S/O
Livingston , Louisiana
Flange-glued or screwed?
2004 28' Safari is the toilet flange glued or screwed to the black water holding tank? Don't want to try to un-screw if it is glued. Thanks
david686 is offline   Reply With Quote
Old 10-30-2012, 08:40 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I'm perry sure it's screwed. When you have the toilet off look at the flange. Mine had yellow rector seal dope on it. So I knew it was screwed. Put two bolts in the flange and use a straight bar across it to move it.
Bigventure is offline   Reply With Quote
Old 10-30-2012, 09:26 PM   #3
Ottawa , ON
Mine is screwed, the tank has a threaded neck. The flange then screws to the plywood floor, of course.
Old 10-30-2012, 09:51 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
They were still using screwed in 2000 actually 1999 when constructed. Used the lever method, but found thin screws don't work, the sealant was thick and it worked with a lot of pressure, bolts are a good idea, I just used a thicker screw in the 2x2.
