Old 03-23-2008, 08:53 PM   #1
2012 27' FB International
Lufkin , Texas
first trip, more stuff to fix
the right hand kitchen sink drain leaked dishwater into the pots and pans below. turns out the culprit is a 1/4 inch hole drilled into the back of the drain line just above the tee connecting the left hand sink. why would that be there? could it be associated with a similar hole drilled into the countertop just behind and to the left of the faucet? any ideas?
Baked Potato is offline   Reply With Quote
Old 03-23-2008, 09:17 PM   #2
Central , Mississippi
Well, thats special. I've never run across a need to drill the drain line in any sort of normal circumstance.
Disgruntled PO's?
At least you now know what to fix...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-23-2008, 09:22 PM   #3
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
A tap for an ice maker or water purifier?
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 03-23-2008, 09:59 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sounds like the same setup I installed in my house for the Reverse Osmosis system. The hole in the drain is used when the system back washes the filters.
Richard
So how do you get the old stuff off? (vulkum) wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-06-2006 09:35 PM
I need some stuff mtnman All Argosy Trailers 20 12-11-2005 06:45 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Stuff for the Airstream Devoman Our Community 5 08-17-2005 07:47 PM
