Old 04-19-2004, 11:52 AM   #1
First Big job.updating toilet from chemi to real
Hello,
Well...as projects go...Steve started this morning on renovating bathroom in the 1972 Sovereign..He plans to take it from original chemical toilet to a real one...EEK first encounter was worms in old tank...Shades of X-FILES....ok back to my questions , Anyone ever do this????.,...Any advice for us novices?? Steve is very handy..we are basically gonna renovate whole thing..but....as all Journies start with the first big step///uh oh I vascilate again.,..Anyhow..this is a sSteve says a disgusiting start...PLease all kind souls Help.. ADVICE>..Like How is best way to remove original tiolet?...anyone ....
ok I will hush...
Always,
Rebecca AKA LUCY in the big Trailer
rheadhuntress is offline   Reply With Quote
Old 04-19-2004, 12:20 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
First, you'll have to define "chemical toilet", and "real toilet".
the "original" toilet was a standard rv/marine toilet. the description for removing/replacing is simple. there are 2 bolts that hold it down to the flange. one is right in front, just under the flush-pedal. The other is hard to reach...its 180 degrees opposite the front one. there is a "knock-out" or plastic cover in the top rim of the toilet bowl. if you take that out, you can reach down in there with a rachet extension, and reach the rear bolt that way.
Anway, they are standard "closet bolts"...same thing that is used to hold down a regular houshold toilet. the bolt has a funny shaped head that slides into a grove in the flange, and sticks up through a hole in the toilet. a nut holds it down.
why are you replacing the toilet? is it broken? something leaking?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-19-2004, 07:08 PM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Are you talking about using a residential toilet?
This would use a lot of water. At least 1.6 gallons per flush. If you are hooked up to sewer the whole time it would not really be a problem. If you are relying on the black tank, it will fill up pretty quick.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 02:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 04:07 PM
Feedback needed for real wood cabinets yukionna Cabinets, Counter Tops & Furnishings 49 05-11-2004 09:45 AM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 10:57 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 03:44 PM
