Old 12-12-2013, 06:28 PM   #1
SilverLocks
abbinb's Avatar
1969 18' Caravel
Louisville , Kentucky
Fiberglass shower question
Hi all, I'm new here. I have a '69 18ft Caravel. I got her mostly gutted, so I'm not sure what was there. I'm planning the shower now and would like to put up my own fiberglass shower surround. I just wanted to know if I should "stick" it to directly to the walls her or should I put up a barrier in case someone in the future, would like to re-renovate? Any thoughts? Thanks!
abbinb is offline   Reply With Quote
Old 12-12-2013, 08:47 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Welcome to the AirForums!
You make it sound like you're maybe planning to get rid of it, and want to make it easier for the next owner to undo all of your good work. Don't look at it that way. Make it the way you want it, because once you have it the way you want it, you'll definitely want to keep it, and there will be no "next owner."
I would suggest that you use "furring" strips (thin, flexible pieces of wood) fastened to the walls directly over the ribs, and attach your shower enclosure to the furring strips. Plus you can take advantage of the furring strips to also install a vapor barrier between shower enclosure and the interior wall, to guard against condensation in inaccessible places.
I've never remodeled a gutted trailer, so my advice is worth exactly 2 just like any other novice's advice. Hopefully someone more experienced will chime in with advice that's more valuable. Or at least more pertinent.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-12-2013, 08:51 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
It is your AS! Build to your taste. Enjoy!
Peace
Channing and Phyllis
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-13-2013, 04:01 AM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I must agree build to your liking and if you ever upgrade to a larger trailer then the next owner has the option to seek guidance fo making any changes. We are doing for our comfort and if we ever sell ours (I will have probably passed on) any future owner can redo to their standard.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 12-13-2013, 05:50 AM   #5
SilverLocks
abbinb's Avatar
1969 18' Caravel
Thanks everyone! I just want to do it right, I don't ever plan to sell her!
Old 12-13-2013, 08:43 AM   #6
aquinob's Avatar
Portsmouth , Virginia
Hi
I redid my bath this last year with a new shower base as well as mounting some fiberglass panels on the walls and used some scrap corian for seating surfaces. The shower are is much more spacious than the original setup with the tub and overhead storage compartments. If you want to see the progress and completion, click on the link to my blog below <points down>
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
