Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 12-05-2010, 03:14 PM   #1
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
Fiberglass Shower Pan
I have surface cracks in my fiberglass shower pan on my 65 Globetrotter. It was treated with new gelcoat 2 years ago. It looked great and I thought that the problem was fixed. I use my shower alot in the summer and after 2 years, the surface cracks have reappeared.
2 Questions:
Question 1: Is this just a cosmetic flaw? Or should I worry about it getting worse?
Question 2: What is the best solution for repair? One Airforum post reccommended Bondo Glass as a fix. I also saw a post that raved about Devcon Seal-N-Place from ITW Performance Polymers.
wheelerimage is offline   Reply With Quote
Old 12-05-2010, 04:40 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
May be stress cracks,and have no functional defects.I think I would reline with fiberglass cloth and then a new gelcoat. Dave
easyride is offline   Reply With Quote
Old 12-05-2010, 10:00 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Polyester resin is much more brittle than epoxy resin. Which did you use? I refinished my fiberglass shower pan in my '61 Safari with epoxy resin and white pigment 4 years ago and it still looks good as new. I used resin only, no glass cloth. The surface cracks have not reappeared. The trailer interior has been through temperatures of below zero to over 100 degrees since the repair.
Sam
samb is offline   Reply With Quote
Old 12-06-2010, 09:04 AM   #4
1955 22' Safari
Butte , Montana
Images: 8
Thanks guys! The gelcoat was done by a "professional." The vintage trailer repair place hired someone to do it. They are out of business now, so I don't know what they used. I purchased some West system epoxy so maybe I'll just do it myself.
As they say, the Titanic was built by professionals, but the Ark was built by amateurs.
Old 12-06-2010, 09:24 AM   #5
1977 Argosy 24
Milltown , Wisconsin
I re did my 64 Avion shower pan. It was full of cracks. What I found was that the pink gel coat was put on way too thick and cracked when the pan flexed over the years. I ground off most of the gel coat some of which was close to 1/4 inch thick, and gave it a new layer of fiber glass cloth on the inside and a new thinner layer of gel coat. Then some white Interlux two part epoxy marine paint. It now looks like new and will not crack like the old one did.
ventport is offline   Reply With Quote
Old 12-06-2010, 09:38 AM   #6
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by wheelerimage View Post
I have surface cracks in my fiberglass shower pan on my 65 Globetrotter. It was treated with new gel coat 2 years ago. It looked great and I thought that the problem was fixed. I use my shower alot in the summer and after 2 years, the surface cracks have reappeared.
2 Questions:
Hi wheelerimage;
Stress cracks in fiberglass can appear for two reasons, one is stress from flexing and the other when gel coat is too thick. Sure way to repair it is to sand gel coat off to where you can begin to see fiberglass. Using light weight glass cloth and epoxy resin re coat entire pan. When it sets up sand the surface with 150 grit and finish with 220. Spray only egg shell thickens worth of a gel coat, being sure not to over apply in corners. Last and very important is proper solid support for the pan. Devcon is not suitable for gel coat "only" repairs. Devcon is for plastics. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Can't get the shower pan out RV H-D Lady All Argosy Trailers 29 02-12-2019 08:01 AM
Removing shower pan guy99 Classic Motorhomes 5 09-30-2011 09:10 PM
Anyone curious about what's under the shower pan? SafeHarbor 1978- 1979 Excella 500 7 12-13-2010 03:22 PM
Bathroom Fiberglass End Cap and Shower Question mello mike General Interior Topics 4 03-25-2010 04:29 PM
using fiberglass to reinforce shower corner charlie tuna Sinks, Showers & Toilets 3 08-31-2006 10:21 AM
