Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-26-2005, 02:42 PM   #1
skeeterville
Profile:
Need Help!!! Fiberglass bath
We have a 1966 Caravel with a fiberglass bathroom in the rear - floor, walls, ceilings, sink and toilet. It has a few previous repairs that look bad and has a lot of grazing and a couple of good cracks (I quess those are really bad cracks). I called a fiberglass repair person who felt some of it could not be repaired - mainly the sink. He also thought that it would cost too much to fix the rest (he has not informed me how much is too much).
Have any of you had similar problems and how did you solve it?
Pat
skeeterville is offline   Reply With Quote
Old 08-26-2005, 03:29 PM   #2
chikagurl
Commercial Vendor
Profile:  1964 19' Globetrotter
charlotte , North Carolina
obsolete bath
Well, there's good news and there's bad news.
Bad news:
The molded fiberglass tub/shower/lavatory unit in those 60's model trailers is obsolete and no longer available anywhere.
Options under this category:
(1) Every once in a blue moon you may see where someone who has gutted a trailer of your variety advertises on the various sites selling its interior parts. Snap them up quickly.
(2) Continue calling high quality craftsmen skilled at fiberglass repair until you find someone confident that they can do the job and pay them.
Good news:
Not only is it possible, but very do-able to fabricate either an aluminum or stainless unit in the same configuration as the original. Im in the process of doing one myself. You need to find someone highly skilled in welding stainless and/or aluminum (both are difficult). Floor plans are readily available to go by...best thing is to find someone with the same trailer that will generously allow you to make cardboard cut-out templates of their bath unit. Once you have pieces cut, material and labor shouldn't be more than $1500 or so. Someone skilled enough with these materials will be able to weld and bend everything just so and when finished it looks quite handsome indeed. Also has a very high cool quotient as well.
chikagurl is offline   Reply With Quote
Old 08-26-2005, 03:38 PM   #3
jsmith351
Profile:  1976 31' Sovereign
1961 19' Globetrotter
Phoenix , Arizona
skeeter,
I'm going throught the same thing now. I have several cracks in the rear bath end cap. I'm considering patching with Fiberglass, sand to finish and recoating with something. I've heard everything from Latex paint to aluminim flashing from Home Depot. On another thread others suggested wood filler for smaller cracks, but I'll try Bondo. I ripped out everything else in the back with exception to this, sorry mine wont fit yours and is already at the land fill.
Hope this has some merit.
jsmith351 is offline   Reply With Quote
Old 08-26-2005, 04:25 PM   #4
jim8860
jim8860's Avatar
Profile:
I work with fiberglass sometimes. The best thing that fiberglass is very easy and most of the time can be fixed. I never seen what the bath looked like in those years AS , but I did own SOB Mh and I had a fiberglass bath as well with no problems and it looked like it was a gelcoat finish. Here is a web site for all your glass needs. http://www.shopmaninc.com Also you can add color with this stuff http://www.shopmaninc.com/pigments.html . What I would do first is small cracks you can fill is a fiberglass based Bondo ( I think is is called Dura Glass?) and if you need to beef it up work it on the back side . I is so hard to give all the answer at once , so if you need to reply back. Good luck ! Jim
jim8860 is offline   Reply With Quote
Old 08-26-2005, 05:13 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Fiberglasss components
All the fiberglass parts that Airstream "ever" made, can easily be repaired and refinished.
All it is, is plain ordinary gel coat and fiberglass.
For someone to say it cannot be repaired is without any merit.
Most of the time, when you see a crack, that crack is in the gel coat only, not in the fiberglass.
Test it with some water to prove the point.
We have repaired tubs, sink tops at the like, even with holes punched in them, along with missing a section of that part.
It does take time and patience. Refinishing them with gel coat is OK, but most of the time, we use automotive type paints.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-26-2005, 05:46 PM   #6
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Do It Yourself?
There's a member on the Forum with the handle Pizzachop. Take a look at his pictures and search on his posts. He has a bunch of information. Start by looking at this and then searching his other threads/posts. http://www.airforums.com/forum...ad.php?t=11197
Good luck.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 08-29-2005, 03:42 PM   #7
skeeterville
Profile:
We'll fix it - Thanks everyone
Old 08-29-2005, 04:41 PM   #8
62 Overlander
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
I had the same problem with my 67 Caravel. I ended up using the vertical pieces as templates to make new from Aluminum and the shower pan and sink I repaired with West System epoxy and fiberglass cloth then shot everything with Rustoleum Industrial two part epoxy paint in the color of our choice. The paint has held up great with no scratches or scuffs and the repairs have held up to use.
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Old 08-29-2005, 08:04 PM   #9
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Can't all fiberglass be repaired?
I must admit, I had the same thought as Andy when I read the fiberglass repair man's reponse. I mean, it's not like you can go down to Lowe's and pick up a new vanity or shower for your unit.
I found that a $10 Bondo repair kit will go a long way in repairing old bathroom stuff. I also used it to repair a crack in the rear endcap on the '73 Sovereign. On the end cap, I had to remove it (kind of difficult to handle as it's a bit floppy once it's removed) and repair it from the backside. I scuffed it up good and applied to layers of glass and resin to it and it seemed to hold. I filled in the crack on the front side with 2 part marine epoxy (shown in picture above) and then sanded it smooth before painting it.
As a pizza maker, I didn't have any experience in fiberglass, so I just read the instructions. Piece of cake! (or pizza) It is important to prep the area (clean and scuffed) so that the resin will adhere to it. It cures fast (60-90 minutes) and can be sanded. Once you paint it (2-part epoxy or whatever), no one will ever know but you, provided you feather the edges.
Check out my new countertop in the Overlander! (I've been working like a madman to get ready for a 6 day trip to D.C./Gettysburg, and the countertop/stove was my goal!)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 09-01-2005, 04:36 PM   #10
skeeterville
Profile:
And - How do I get it out of there?
Well it looks like to bottom portion of this fiberglass wet bath has to come out. Can anyone give some idea how to go about this project?
Old 09-01-2005, 08:49 PM   #11
moogie32
moogie32's Avatar
Profile:  1967 22' Safari
Branford , Connecticut
Images: 11
Been there...
Hi Pat, I gutted my whole interior with the intent of refinishing everything including the bathroom. I don't have cracks in mine but it is faded and stained and needs to be refinished. It is possible to remove just your bathroom but it makes the job a whole lot easier if you remove more than just the bath fixtures. I don't know how you'd get the tub out without removing the partition wall (in my Safari there were rivets that were inacessable to drill out with the wall in place). Once you start disassembling things it should become pretty logical about what needs to come out next. I know there's a thread somewhere in the archives specific to bath removal try a search for it. Good luck, take good notes and plenty of pictures as it comes out and don't discard anything until it's back together and you're satisfyed with the job. Even then there may be people interested in purchasing anything you don't want to keep.
Good luck, Diane
moogie32 is offline   Reply With Quote
Old 09-18-2005, 10:11 AM   #12
BURNZEE
Profile:
I have removed my tub/sink/toilet cover fiberglass unit in my 66 Safari to do floor repairs. While it was removed, my intent was to repair and repaint it outside of the trailer, but it won't fit out the door. It is currently resting on the front Gaucho. Has anyone had good results painting it in place, inside the trailer? Can the two-part epoxies be brushed on, or are the brush strokes evident?
BURNZEE is offline   Reply With Quote
Old 09-18-2005, 01:04 PM   #13
Commercial Vendor
BurnzeeEvery Airstream trailer, ever built, would allow all of the interior components to go throught the entrance door.That's how they built all the trailers.Perhaps you have two pieces that can be separated.Andy
Inlandrv.com
800-8777311
Old 09-18-2005, 03:04 PM   #14
StingrayL82
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Burnzee,
Call Ron, at South Jersey RV...856-697-9600...he'll be more than happy to talk you through taking your bathroom apart....he's really knowledgeable and friendly.
Frederic
SSG Frederic Lynes
1971 31' Sovereign, restored
2004 F350 King Ranch
StingrayL82 is offline   Reply With Quote
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 09:52 PM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 06:09 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 10:00 AM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 04:58 PM
Bath lites a new type of lite FrankR Electrical - Systems, Generators, Batteries & Solar 2 03-16-2002 09:38 AM
