Old 06-24-2009, 10:53 PM   #1
1969 21' Globetrotter
Cambridge , Massachusetts
Fiberglass bath lay up
I would like to build a custom (no lavatory) wet bath across the back of my '69 Globe Trotter using a fiberglass surround that would integrate floor and walls extending up to the underside of the existing fiberglass endcap. Before laying up the fiberglass, the floor would be pitched to a central drain using rigid insulation tapered from 1” at walls to 1/4” at drain and the walls would be covered with an eighth to quarter inch of foam material to allow a little extra flexibility between the aluminum shell and the fiberglass. In addition, a fillet of 2” or so would be provided between the floor and walls. Does this sound reasonable so far? My questions regarding fiberglassing are as follows. What combination of fabrics (chopped, cloth, rovings etc.) and weight of fabric would be appropriate for the floor? For the walls? Most literature I've seen discusses fiberglass with exposed side laid up on a smooth form. In this case the exposed side will be a free surface (not formed). How is a nice smooth finish accomplished in this case? Can anyone recommend forum threads, blogs or “how to” books appropriate to this project? Any help or advice regarding this project would be greatly appreciated.
JoePfznik is offline   Reply With Quote
Screwing into fiberglass bath ceiling? SummitAir Sinks, Showers & Toilets 4 10-22-2008 11:16 AM
Need Help!!! Fiberglass bath skeeterville Sinks, Showers & Toilets 22 10-24-2007 06:03 PM
Lay some skin on me brotha !! airstreamcaravel Ribs, Skins & Rivets 12 11-25-2005 10:57 AM
And now I lay me down to....... krowsea Cabinets, Counter Tops & Furnishings 13 10-12-2004 09:05 PM
wants to lay down on the hills wb13798 Mechanics Corner - Engines, Transmission & More... 42 10-27-2003 06:41 AM
