Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 03-12-2003, 06:31 PM   #1
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Faucet replacement/upgrades
Are there any particular faucets I should consider, if I wanted to "upgrade" my faucets that came with my Bambi.
I know for homes, it's pretty open and shut, but given using a pump, I didn't want to get something that would not allow some pressure.
Any thoughts? Been looking at the home supply stores in the area and the connections look very similar to the ones in the house that the Bambi has.
Regards,
Eric
Old 03-12-2003, 06:48 PM   #2
Rickk48
Rickk48's Avatar
Profile:
I think you can use pretty much use any faucet with standard plumbing hookups. The upgrade on the Bambi uses the same Moen as is used in a house.
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 03-12-2003, 07:17 PM   #3
Silvertwinkie
Aluminut
Thanks for the post Rick. I had the same feeling. I took a look at the connections and they did look similar. The faucet in the back is a nice one, but the one at the kitchen sink is a bit weak-- even with the external sprayer.
Regards,
Eric
Old 03-12-2003, 11:53 PM   #4
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Our good fortune, for a change, the one thing that Airstream didn't custom make is the sink and lav faucets. Visit your neighborhood homecenter and spend as little or as much as you can afford. They are US plumbing standard drilled holes.
If your lav is a combo shower/faucet fixture, you might have to go to a marine or RV supplier. They will have a larger selection of this type of combo fixture.
-BobbyW
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 03-13-2003, 08:19 AM   #5
Silvertwinkie
Aluminut
Thanks Bobby.
I had a feeling by looking at it that it seemed to be pretty standard. But you know Murphy's law being what it is, I'd have the thing apart and find otherwise if I didn't ask.
Eric
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 10:44 AM
Mystery Faucet on 92 Land Yacht MH DaveJ Airstream Motorhome Forums 5 10-26-2003 10:59 AM
Brita Faucet Filters Sneakinup Water Heaters, Filters & Pumps 3 10-14-2003 07:21 PM
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 07:21 PM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 06:02 PM
