Old 04-14-2010, 04:31 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Faucet is running when turned off
I fixed my leaky/frozen pipe problem, but now when I pressurize the system water is coming out of the kitchen faucet, even when it is completely turned off. My faucet is fairly new, I just replaced it a few years ago. It's an american standard #2475F Colony Soft Bar Faucet. I don't know much about faucets, what should I look into to fix this problem?
Stephanie
Old 04-14-2010, 04:40 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I think your leak problem was the result of freezing. If that is the case the faucet may also be a victim of the freeze.
If it is a newer faucet it may have a cartridge inside. remove the arm and remove the cartridge for inspection and cracks.
2004 Excursion 4x4
Old 04-14-2010, 04:41 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I took a look at your faucet on-line and noticed that it is a double handle type. It should have some type of washer unit in the handle shaft. If you still have the paperwork that came with the faucet, it may have some repair instructions and part numbers.
Brian
SuEllyn & Brian McCabe
Old 04-14-2010, 05:41 PM   #4
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
I am with HowiE . I think it has a cartridge in it. It has a something stuck in it or it is cracked and leaking.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 04-14-2010, 06:04 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Ok, I got the cartridge out, it looks ok. I'll run it by the hardware store and see if they have replacement washer/o-ring for it. Maybe that will do it.
Stephanie
Old 04-24-2010, 08:22 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I had to order the parts online and they finally arrived. I replaced both because I figure if one had gone the other could not be far behind - they were only $6 each. They worked perfectly. So now the trailer is leak free, I've tested all the appliances, put the towels and sheets back into the trailer, and it's ready to roll
Stephanie
leaks
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Who Turned down the Thermometer wingfoot321 Off Topic Forum 0 03-21-2006 10:29 PM
Help with water faucet Dan Roach Fresh Water Systems 3 09-13-2005 10:32 PM
Turned off by the new Safaris Raptorrider2001 Our Community 17 09-08-2005 01:33 PM
Need a faucet Chitown AirStreamers Fresh Water Systems 4 09-10-2003 07:24 PM
