Old 09-10-2014, 07:28 AM   #1
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Exterior Shower - no pressure
We had a 23fb with an exterior shower which we used a couple of times to hose off the kids. I don't remember the water pressure being an issue (not great but usable). We now have a 25FB and the exterior shower is almost un-usable. However, the shower unit seems to have changed slightly between our 2011 23fb and our 2014 25fb. I'm just curious if anyone else has noticed low pressure on their exterior showers.
Landrum is offline   Reply With Quote
Old 09-10-2014, 09:17 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Take the hose and head loose at each connection, there may be trash in the hose from the factory.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-10-2014, 09:17 AM   #3
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Interesting. We have a 2014 Sport 22FB. I have never opened the outside shower compartment, but will check it out now that you indicate there may be a problem. I guess there is a shower hose in there! I am one of those guys that wants something to work, even if I rarely use it.
Cannonball is offline   Reply With Quote
Old 09-10-2014, 10:01 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Ours works fine (assuming good pressure into the trailer or the water pump.) You probably have some blockage.
Bob Martel
WBCCI# 5766
Old 09-10-2014, 12:31 PM   #5
Gainesville , Florida
Pull hose all the way out to see if it is kinked. Jim
Old 09-14-2014, 05:43 PM   #6
Landrum's Avatar
Well we went camping this weekend, but I forgot to mess with the shower. Ok I'm not being honest.....I was just too lazy to get out of my chair. Anyway when I got home I took the shower apart to look for trash. No trash but I found a couple of problems. I'm not sure what order the pictures will show up on my post but:
1 picture shows the outside of the shower head with a lever to temporarily turn off the water
1 picture shows the mechanism for turning off water temporarily. There is a little plunger that water pressure pushes up to allow water to flow. However the amount of space around the plunger is very small.
1 picture shows where the shower hose connects to the controls. There is maybe a 1/8" hole to allow water into the hose.
I removed the plunger from the head. I don't really need the ability to temporarily shut off the water. If this doesn't help with the pressure I may drill a larger hole where the hose connects.
I do plan on upgrading to the stainless steel shower unit at some point. These adjustments just need to hold me until I can upgrade.Click image for larger version
Name:	ImageUploadedByAirstream Forums1410738014.580097.jpg
ID:	221865Click image for larger version
Name:	ImageUploadedByAirstream Forums1410738041.954633.jpg
ID:	221866Click image for larger version
Name:	ImageUploadedByAirstream Forums1410738195.581856.jpg
Old 09-23-2014, 09:18 PM   #7
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Ok, checked outside shower this past weekend. Pressure very poor. No blockage in hose. I use an exterior pressure regulator in addition to the one built in to the Airstream. Will remove that and try again.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Old 09-24-2014, 07:12 AM   #8
Landrum's Avatar
I tried my shower using the water pump after removing that "plunger" in the shower head, and the pressure was much better. I suspect the pressure will be even better with a city water hookup (versus the water pump pressure).
Old 07-03-2015, 09:17 PM   #9
mandolindave's Avatar
You got me thinking………
Is the problem not enough pressure, not enough water, or both?
Would more pressure from city water, just make the water shoot farther?
And would the bigger orifice just allow more volume of water?
mandolindave is offline   Reply With Quote
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Help: Shower and Toilet work; No water pressure in sinks donshade Fresh Water Systems 4 06-13-2009 06:16 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Shower Pressure Skinner1 Fresh Water Systems 6 10-15-2005 06:52 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
