Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-11-2007, 11:21 AM   #1
Gkiesel
Profile:  1976 24' Argosy 24
Milford , New Jersey
Exterior Shower Leak
Hello all, Got a tough one. Just returned from Mystic Conn. We have a rear bath 24 Argosy 1976. After using the shower we noticed that the floor just outside the bathroom is slightly wet and more disturbing there is water visible under the trailer. It seems that the drain line has either seperated or broken? Don't really know. Any ideas? Also where can one get a plumbing schematic for an old Argosy? Any Help would be appreciated. Thanks, George
Gkiesel is offline   Reply With Quote
Old 06-11-2007, 11:55 AM   #2
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
My '77 Ambassador had similar symptoms but it was the shower selector valve. The water was running out of the assembly, up behind the knob and back down the pipe onto the wooden floor. A Moen replacement insert fixed the problem.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 06-11-2007, 12:29 PM   #3
garthbf
garthbf's Avatar
Profile:  1975 31' Sovereign
mount vernon , Washington
I had same kind of problem. Turned out to be the copper line that goes from the valve to the shower hose connection was split from freezing.
garthbf is offline   Reply With Quote
Old 06-12-2007, 11:11 AM   #4
Gkiesel
I think you guys are suggesting that it's the water valve that's leaking. I kind of assumed it was the drain line. I wiil investigate further. The argosy just has a single outlet faucet in the shower area, with a flexible hose attachment for a shower head. I don't think it leaks with just the water hooked up and turned on but I will check.
Old 06-12-2007, 11:28 AM   #5
HiHoAgRV
Images: 26
Mine has a typical shower arrangment, hot handle, cold handle a a diverter handle to switch the flow from the faucet to the shower head, just like in a home tub. The diverter valve was leaking and only when the shower was being used.
You should hope that's the culprit - it's an easy fix.
Hi Ho Silver RV!
Old 06-12-2007, 01:26 PM   #6
Gkiesel
Wow that's pretty cool. What a difference a year makes. Mine is just a shower, no tub, but to use it you have to scew the flexible hose onto the bottom of the faucet outlet, turn on hot and cold to taste. No diverter valve, no internal plumbing going up to a shower head. I suspect a broken drain line. What's odd is that for the plywood floor to get wet, the leak must be pretty high. Like the drain outlet itself. I'll know better this weekend after a few hours lying in the driveway.
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 08:39 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
