Old 08-01-2014, 10:55 AM   #1
I Bought it I Broke it...
clicknathan's Avatar
1976 31' Sovereign
Migratory , North America
Experience Replacing Toilet in a '70s era AS
At some point a PO put in a big ol' regular ceramic toilet which isn't working out for us and reserving water.
Was thinking of getting this model, which is ceramic as well, but specifically for RVs.
Dometic High Profile 310 Series Gravity Discharge Toilets - White - Dometic 302310011 - RV Toilets - Camping World
Anyone with experience replacing a toilet have any reservations about that choice?
clicknathan is offline   Reply With Quote
Old 08-01-2014, 11:57 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
When I replaced the toilet in my 68 I got a toilet with the pedal on the left side because the bathtub is right up against it on the right hand side. That is the only consideration I can think of. The china bowl is a nice thing to have and easy to clean.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-01-2014, 01:55 PM   #3
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
When we replaced the original Thetford Aqua Magic Bravura in our 1980, we opted for one a step up - the Style II because it reminded me more of a residential toilet. I also like the step flush feature. It wasn't difficult to install and we really like the new clean look of a new potty!
Good luck!
Rhino33 is offline   Reply With Quote
Old 08-01-2014, 02:32 PM   #4
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Nathan,
Don't buy a DOMETIC. Look for a similar model by THETFORD.
DOMETIC thinks their customers are their distributors. They won't deal with you directly and you could be left hunting for a part for weeks.
THETFORD knows that YOU count. They will send you a part from their warehouse the day you call them.
I have pieces from both manufacters in my waste management system so I give you this advice from experience.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 08-01-2014, 06:27 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I installed a Dometic 310 with a plastic bowl. I didn't want the ceramic due to the weight. I have enough weight at the rear of my trailer thanks to the rear bath. I felt the design quality was higher than Thetford's product.
I did have trouble with the plastic pipe thread connection molded to the toilet. It has a protrusion on it that prevents good thread engagement of the standard flex connection hose. I have no idea why there is a protrusion on the plastic threaded inlet. I can say pipe threads molded in plastic aren't the greatest. I'll take brass any day.
The flange seal at the floor seemed good. There was healthy gasket compression as I seated the toilet to the mounting flange. I did not have to use a wax seal.
We'll see how it lasts.
David
Old 08-05-2014, 05:34 AM   #6
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Replacing toilet, recommendations
Thetford Bravura toilet in 2004 Classic. The valve seal leaking water from the bowl, replacement parts almost half the cost of total replacement and I would like something a little more comfortable, so looking for advice. I need low profile, want china, elongated seat, not certain about water saver?, quality. Looking at the Thetford Aqua Magic Plus, Sealand 511 Plus, Dometic 320. Current setup is 2 bolt. We are not large people, but the seat configuration on the Bravura is kind of cramping my style. Any opinions/advice as always would be appreciated.
Rod
rbs is offline   Reply With Quote
Old 08-05-2014, 09:07 AM   #7
1976 Argosy 24
Rob,
Just to repeat my advice from the post above' choose something suitable from THETFORD. The DOMETIC distribution system is the s**ts..
Sergei
Old 11-12-2014, 08:33 AM   #8
1976 31' Sovereign
I did end up going with the Dometic...not sure if that will bite me in the longrun with the opinions here (seem to be a some for and against both Thetford and Dometic).
Installation wasn't a problem and it's working wonderfully. Nice not to use the entire freshwater tank every time we flush.
My family and I have been full-timing via various modes of travel since 2008. Going on two years in our '76 Sovereign.
Old 05-04-2015, 08:06 AM   #9
Missoula , Montana
Bolt pattern?
did you have any problem with the bolt pattern's on the new vs the old, my old toilet ( 72' 31' center bath) has a 4 bolt pattern, and all of the new toilets are 2 bolts and not in the same location.
thanks.
wolf38 is offline   Reply With Quote
Old 05-04-2015, 08:10 AM   #10
dznf0g's Avatar
Oswego , Illinois
My 310 has been fine. Same as above...Thetford parts are expensive. Mine started leaking and the parts were more than half the cost of the new taller ceramic bowl Dometic complete unit.
-Rich-
'70s era interior door hinges 4RXLA Doors & Locks 4 10-08-2014 08:23 AM
Experience replacing overpressure relief valve? flyflinger Fresh Water Systems 3 06-04-2013 10:02 AM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Experience with a Thetford Recirculating Toilet? 60's Iron Waste Systems, Tanks & Totes 2 06-21-2008 09:08 PM
'70s era TV stands/mounts Safari Tim Interior Restoration Forum 0 07-05-2003 05:24 PM
