Dometic 310 water leak
Good morning. We put a Dometic 310 in our 2009 27FB in November as an upgrade from the old plastic OEM toilet. We're on a multi-month trip and we've started seeing water seeping out from under the base. A little research here indicates this is a design flaw and there is no fix as the leak is between the porcelain and plastic parts. Before we get home and I pull the toilet to investigate I thought I would be hopeful that someone has found a solution. We love the toilet and tight quarters don't give us many options for other models.
Thanks in advance for your collective wisdom.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
