04-23-2015, 09:40 PM
#21
2007 25' Safari FB SE
Santa Cruz
Thanks so much aftermath! We'll probably do as you did. Very glad to have a solution.
(Having a Zag niece, we appreciate your part of the world!)
Janet
04-23-2015, 10:26 PM
#22
2008 27' International FB
Petaluma
Here's the posts RE my attempt to put a 320 in a 27FB. The 320 is elongated ( doesn't fit) so Camping World Swapped it with a 310 (with money back) so I installed it with the sprayer add on. I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it. http://www.airforums.com/forums/showpost.php?p=1382638
- Brad Sent from my iPad using Airstream Forums
Looking for adventure in whatever comes our way.
- Brad
04-23-2015, 11:05 PM
#23
Santa Cruz
Good info. Thanks SuperTrooper.
Janet
04-24-2015, 07:44 AM
#24
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Originally Posted by SuperTrouper
Here's the posts RE my attempt to put a 320 in a 27FB. The 320 is elongated ( doesn't fit) so Camping World Swapped it with a 310 (with money back) so I installed it with the sprayer add on. I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it. Replacement Toilet? - Airstream Forums
Thanks Brad, I forgot to mention you in my OP, as that thread is the main one I found with info to this toilet that helped me install it in my year trailer. I really appreciate that you always include photos in your posts too. I'm a visual learner, and that always helps me.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
04-25-2015, 12:40 PM
#25
2004 30' Classic
Hillsborough
, New Jersey
toilet replacement
"I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it."
I was pleased to see that your area has a recycling area to take the old toilets. This way we don't fill up our dumps and something can be done with the old stuff.
04-25-2015, 01:01 PM
#26
2008 25' Classic
Full Time
Thetford makes porcelain toilets. Maybe they would fit better. Aqua Magic Style Plus and Style II
What is the distance between the center of the drain hole and the wall on your installs?
Kelvin
04-26-2015, 07:47 PM
#27
Nomadic
, USA
Kelvin
Couldn't tell you that. But the Aqua Magic Plus looks too big.
04-27-2015, 12:11 PM
#28
2008 25' Classic
Full Time
The Thetford Plus shows 11" from the center of the drain hole to the rear outside edge and the Style II its 9 1/2".
The Thetford Aqua Magic V which looks like my current toilet in my 25fb is 7 5/8".
I found a spec sheet for the Dometic Sealand 310 and it's 9 5/8" while the 320 is 10 1/2"
Kelvin
02-06-2016, 07:29 AM
#29
2006 25' Safari
St. Augustine
I know the post is about 10 mths old but after just installing a Dometic 311 (the shorter version) I can say that the Aquamagic is 7-5/8" from center of drain to back while the 310/311 is 10" so you need at least 2 3/8" to spare for the 310 beyond the already installed aqua magic plastic throne for it to fit.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
07-31-2020, 10:44 PM
#30
Oklahoma City
, Oklahoma
Toilet install
I installed the 310 in my 2007 international. We love it. Installation was easy. It is very close to the wall but still works. Thanks to Bold Adventure for the installation info. I used the pex crimp on fitting rather than the shark bite. Was able to borrow a tool to do the crimping. My valve was separate from the line. One thing that may save someone a trip to the hardware store, the fitting on my 310 was not the standard toilet fitting but a sink fitting. Label from the hose reads 1/2" FIP / 3/8" comp. The 3/8" end went on the valve.
