Old 04-19-2015, 09:02 PM   #15
1972 27' Overlander
Woodburn , Oregon
How much does this toilet weigh ?
shineybullet is offline   Reply With Quote
Old 04-20-2015, 06:51 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The Dometic 310 porcelain toilet came standard in our 2013 Classic.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-20-2015, 07:21 AM   #17
Alden Miller's Avatar
1993 34' Excella
, Maryland
Gee thanks! Now I have something else that I might want to do to my Airstream!
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 04-20-2015, 08:40 AM   #18
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
32.4 lbs.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-23-2015, 08:31 PM   #19
janetb's Avatar
2007 25' Safari FB SE
Santa Cruz , California
Thanks for the nice report, BA. We have a 25' fb, and the specs for the 310 indicate it won't fit. Has anyone found a porcelain toilet that would work in a 2007 25' Safari? The plastic needs to be dethroned, and the sooner the better. Thanks for any suggestions.
Janet
janetb is offline   Reply With Quote
Old 04-23-2015, 09:21 PM   #20
aftermath's Avatar
Spokane , Washington
Janet,
We have a 2006 25 FB and the 310 does fit....but.....it took a bit of work to get it in. There is a plastic valve with a plastic covering that sits on top of the toilet. I had to trim off some extraneous pieces of the valve and then trim a part of the plastic cover. It is tight to the wall but fits now and works GREAT. Our old plastic one was getting rather gross and was hard to keep clean. This porcelain bowl is really much better.
aftermath is offline   Reply With Quote
Old 04-23-2015, 09:40 PM   #21
janetb's Avatar
Thanks so much aftermath! We'll probably do as you did. Very glad to have a solution.
(Having a Zag niece, we appreciate your part of the world!)
Janet
Old 04-23-2015, 10:26 PM   #22
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Here's the posts RE my attempt to put a 320 in a 27FB. The 320 is elongated ( doesn't fit) so Camping World Swapped it with a 310 (with money back) so I installed it with the sprayer add on. I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it. http://www.airforums.com/forums/1382638-post.html
- Brad Sent from my iPad using Airstream Forums
SuperTrouper is offline   Reply With Quote
Old 04-23-2015, 11:05 PM   #23
janetb's Avatar
Good info. Thanks SuperTrooper.
Janet
Old 04-24-2015, 07:44 AM   #24
Nomadic , USA
Originally Posted by SuperTrouper View Post
Here's the posts RE my attempt to put a 320 in a 27FB. The 320 is elongated ( doesn't fit) so Camping World Swapped it with a 310 (with money back) so I installed it with the sprayer add on. I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it. Replacement Toilet? - Airstream Forums
Thanks Brad, I forgot to mention you in my OP, as that thread is the main one I found with info to this toilet that helped me install it in my year trailer. I really appreciate that you always include photos in your posts too. I'm a visual learner, and that always helps me.
Old 04-25-2015, 12:40 PM   #25
2004 30' Classic
Hillsborough , New Jersey
toilet replacement
"I took the old Thetford to our county recycle center and placed it with all the other old toilets. I'm sure someone made use of it."
I was pleased to see that your area has a recycling area to take the old toilets. This way we don't fill up our dumps and something can be done with the old stuff.
wolf146 is offline   Reply With Quote
Old 04-25-2015, 01:01 PM   #26
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Thetford makes porcelain toilets. Maybe they would fit better. Aqua Magic Style Plus and Style II
What is the distance between the center of the drain hole and the wall on your installs?
Kelvin
Old 04-26-2015, 07:47 PM   #27
Nomadic , USA
Kelvin
Couldn't tell you that. But the Aqua Magic Plus looks too big.
Old 04-27-2015, 12:11 PM   #28
KJRitchie's Avatar
2008 25' Classic
The Thetford Plus shows 11" from the center of the drain hole to the rear outside edge and the Style II its 9 1/2".
The Thetford Aqua Magic V which looks like my current toilet in my 25fb is 7 5/8".
I found a spec sheet for the Dometic Sealand 310 and it's 9 5/8" while the 320 is 10 1/2"
Kelvin
Toilet Seat Upgrade for Dometic 310 Bluto Sinks, Showers & Toilets 6 03-08-2016 03:09 PM
Porcelain burner diffuser thingy '62 or '63 Andrew M. Franklin Refrigerators 2 11-02-2012 07:38 PM
Townsend Porcelain toilet repair. toothDr Sinks, Showers & Toilets 10 05-25-2009 03:37 PM
Water Heater Fix - Try drying the porcelain electrode guy.random Water Heaters, Filters & Pumps 1 10-23-2007 03:59 PM
Thetford porcelain to slide valve gasket ? IndianaJeff Plumbing - Systems & Fixtures 8 04-24-2006 02:07 PM
