Old 04-07-2019, 09:39 AM   #1
Tamaroak
Stillwater , Minnesota
Divert greywater to toilet
Why not put in a Y valve at the sink drain to capture that water for use in the toilet? This would save freshwater and put more water in black water and less in grey water
Tamaroak is offline   Reply With Quote
Old 04-07-2019, 11:03 AM   #2
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
Haven't figured that one out, but we do use a separate dish tub for soapy water and pour that down the toilet when finished. It helps divert a few gallons each day.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is online now   Reply With Quote
Old 04-07-2019, 02:52 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Gotta be a back flow/venting problem Im sure....imagine a waft of blank tank stank invading your kitchen while doing a dish....
FL Crackers has it right - we do the same - soapy dish water in a dish tub makes it to the black tank as does a shower bucket that catches all the cold water while the hot is making its way out and frankly can be in the shower while taking a shower so even if only a couple gallons makes it in the bucket, its great for the black tank.
SteveSueMac is online now   Reply With Quote
Old 04-07-2019, 03:59 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Back before I had the much-thirstier macerating toilet, I made a point to do the dish-tub trick, and to keep a bucket in the shower that captured part of the shower water and used that for flushes, etc. Now, the black fills at almost the same rate as the gray because the macerator toilet uses WAY more water per flush than the gravity toilets. If you have a gravity toilet (probably 98% + of Airstream/Argosy trailers?) it's definitely worth the effort for extended boondocking.
David
Old 04-07-2019, 04:29 PM   #5
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
What are you trying to accomplish? Extend boondocking stays? Capture sink water into what? Then pour it or add a pump and replumb and deliver to toilet under pressure. You would have to keep food particles out of that water I am thinking.
WW
By being so focused on how things 'could' be, we are under-appreciating how great things already are - Timber Hawkeye
Wolfwhistle is offline   Reply With Quote
Old 04-08-2019, 10:49 AM   #6
2018 25' Flying Cloud
Portland , Oregon
Ive always though it would be handy to have a simple way to open a value or press a button to allow the transfer of SOME water from the grey tank to the black tank when bookdocking and the grey is getting full. I have one of these gate valves that I COULD use to equalize the two at the output end but it would result in some co-mingling of black into grey which Im not crazy about.
Any ideas?
daleyocum is offline   Reply With Quote
blackwater/greywater tank 72 tradewind roguebrun Waste Systems, Tanks & Totes 18 01-30-2019 12:20 PM
I Broke the Greywater Dump Valve Handle 1Michigander Waste Systems, Tanks & Totes 10 06-26-2014 06:24 PM
1969 Tradewind adding a greywater tank paul z-air Waste Systems, Tanks & Totes 0 09-12-2010 08:47 PM
Sink drain creates toilet bubbles, greywater always reads full dre00 Plumbing - Systems & Fixtures 22 02-02-2009 12:13 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
