Originally Posted by obxgal Hi all...
our "new to us" 1975 Excella 500 has a crack about 1.5" long. It is along the outside curved edge on the floor pan. What have you all been using to make repairs? Is this a fiberglass repair or is it a molded plastic? Any help will be very appreciated!
Susan |
Hi Susan,
When we bought our used 2005 Classic, it had a small crack about the same size in the bottom of a curved section of the wall. I left it alone for our first couple of trips, but had the impression it was growing due to trailer movement.
I'm sure there are better ways to repair it, but all I did was to drill a small hole at the root of the crack (a standard technique used to stop cracks from progressing) and then used a clear sealant I had that dries quite hard but still flexible to fill the hole and to seal the crack in order to stabilize it more and to prevent water entering.
Its not invisible, but doesn't look that bad either and I can keep an eye on it! When we are camping, it is usually hidden behind shampoo & shower gel bottles on the shower seat anyway!
Travelled a few thousand mikes with it since and no problem as yet.
I figured that in trying to repair it and make it look invisible, I'd probably only make it look worse and draw more attention to it!
Brian.
