Old 03-13-2012, 11:18 AM   #29
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Not yet. Had a few more things to do before this came to the top of the list. I'll be working on it soon.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 03-23-2012, 12:22 PM   #30
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Hi SilverCabin
Any updates?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 04-01-2012, 10:54 PM   #31
JFScheck's Avatar
Rockville , Maryland
Images: 33
So - can't wait to see updates with before and after pics pretty please!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-02-2012, 05:11 AM   #32
1973 25' Tradewind
Augusta , Georgia
I'm in the middle of restoring a 1973' Tradewind and have similar cracks. I believe the material is an ABS plastic. I don't believe that polyester (fiberglass) or epoxy resins will bond well with this material. There is also a heat with polyester resins that I'm afraid may melt/warp the item. I'm looking at a relatively new product from West Systems called G-Flex epoxy. There promo includes cutting a plastic kayak in half and glueing it back together.
WEST SYSTEM | Specialty Epoxies - G/flex
This is available form marine hardware/repair shops - West Marine, Jamestown Distributors
DGJackson is offline   Reply With Quote
Old 04-04-2012, 09:54 PM   #33
JFScheck's Avatar
Images: 33
Colonial Airstreams has an individual who is coming in to repair my crack that was created when the shower stall was installed. Suggest everyone give them a try!
**I Love U.S.A.**
Old 04-05-2012, 11:03 AM   #34
blickcd's Avatar
Milford , Ohio
I've had a few small cracks over the years and repaired them with a kit that I got from my RV parts supplier. I think the brand name was Devcon but can't remember for certain.
For more serious cracks I first stop-drilled the ends of the crack. Then mixed up the two-part resin, which I coated over the crack. The kit comes with a small patch of fiberglass cloth which I've used to reinforce cracks that are 1" or longer.
My shower pan is an almond color and the kit comes in a similar color though it is not a perfect match. No problem though since most repairs are hidden under a rubber mat, and my goal was to stop the cracks from spreading and prevent any leaks.
Christopher
blickcd is offline   Reply With Quote
Old 04-05-2012, 03:13 PM   #35
Viera , Florida
Smile The Repairs Begin
I'm back. Had a few things like home chores and taxes get in the way of my Airstream repair, but I made a little progress this week. Here's a look at the kit I got from Ultra/Glas, and a pdf of the instructions.
Old 04-05-2012, 03:16 PM   #36
Viera , Florida
The Repairs Begin - 1
First step is to scratch out the crack. This also is when you find out if there are any chips, or if the crack is more than just the gel coat. Mine is just in the gel coat and no chips.
Old 04-05-2012, 03:18 PM   #37
Viera , Florida
The Repairs Begin - 2
Next step is to sand the area around the crack. Not wanting to create a large area to finish, I wrapped a sheet of 180 grit sand paper around the end of my utility knife with the blade extracted.
Old 04-05-2012, 03:19 PM   #38
Viera , Florida
The Repairs Begin - 3
Here's the area after sanding is complete.
Old 04-05-2012, 03:20 PM   #39
Viera , Florida
The Repairs Begin - 4
And this is what it looks like after cleaning with Acetone.
Old 04-05-2012, 03:27 PM   #40
Viera , Florida
The Repairs Begin - 5
I'm now trying to get the right mix of gel coat and catalyst. It's a little tricker than it seems, but I think I have the right number of drops of catalyst per Tablespoon of gel coat. Too much and it stays a little sticky when dry. Too little and it never hardens.
When mixed properly, it has the consistency of latex paint. I will probably use a small throw away artists's brush apply it.
I'm away for the next two weeks, so I won't get back to this until the end of the month. Have to get this done as we leave for Alaska on Memorial day.
Randy
Old 04-05-2012, 04:17 PM   #41
1973 31' Sovereign
2007 20' Safari SE
hmmmmm
this is very interesting...
thanks for the very detailed post...
Please keep it coming!
2 chronicles 7:14
Old 05-03-2012, 03:54 PM   #42
Viera , Florida
I'm back and I've finished the job--sort of.
Here's a photo of mixing the gel coat. One tablespoon gel coat to two drops of the hardener creates the right mix. It has the consistency of latex paint, and doesn't begin to harden for about 20 minutes.
After it hardens, it feels sticky, but the Acetone wipe and sanding take that away.
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
Repair a Crack on Shower Floor max7 Sinks, Showers & Toilets 5 03-30-2010 02:50 AM
New shower stall bullydogsmom Sinks, Showers & Toilets 4 06-10-2009 05:20 PM
Shower Stall? chr$ Interior Restoration Forum 1 05-31-2004 09:58 PM
Shower stall repair Franklin Sanders General Interior Topics 4 08-31-2003 06:24 PM
