Old 05-09-2005, 01:07 PM   #1
Ferroequine's Avatar
1975 23' Safari
Calgary , Alberta
Crack in shower on a rear-bath
While de-winterizing the Airstream last weekend, we noticed a couple of large cracks in the shower wall, near the roof. This is on a '75 Safari (rear-bath) which is otherwise in very good condition. It is always stored outside, and the winters here can get pretty cold.
Has anyone ever had this happen, and what should I use to fix it? Also, after I started thinking about it, since the cracks are near the top of the roof, could this be a precursor to rear end sagging?
ID:	12059   Click image for larger version
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 05-09-2005, 01:26 PM   #2
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
In a word, yes. Something moved and pressed in on that shower to cause it to crack. Having just removed our tub (easier, to a measure, in an old unit, since it was smaller), I can tell you that everything is very tightly fitted in there.
There is good news. It can be repaired. It appears to be fiberglass. Boat shops can make repairs that will make it look better than ever. Or you can try doing it yourself (lots of sanding and epoxy work).
Better news--which may not seem so good from your current perspective--is that you will have to remove the tub/shower to get it repaired. That is good news, since it will put you in a place where you (or your repair guy) can identify what is causing your problems. It may be rear end separation, it could be other causes of problems. Repair is painful, but you will be left with the confidence that you have a trailer that you can rely on.
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Moving the Rear Bath Forward? jabra General Interior Topics 6 07-05-2016 11:52 AM
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 08:45 PM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 09:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 09:28 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 10:00 AM
