Old 07-09-2011, 12:11 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Correct toilet flange?
I've pulled the Thetford Bravura toilet which was mounted with 2 bolts at 5 and 10 o'clock positions. I'm about to mount the Sealand Traveler 511H low profile ceramic toilet and was wondering if the flange pictured below is a universal one? It looks like the flange will take the 4 bolts that came with the new toilet but the new seal inner diameter looks much larger inside diameter than the one it replaced. Am I still good to go? Rats, can't get my picture to post.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-09-2011, 12:20 PM   #2
davidz71's Avatar
1986 25' Sovereign
OK, the finally opened up.
Name:	toilet flange 002.jpg
Craig
AIR #0078
3.73 rear end
Old 07-09-2011, 01:47 PM   #3
1976 Argosy 26
Fair Oaks , California
You can do one of two things. Change the black tank flange to the four bolt style from Vintage trailer supply.
Sealand 4-Bolt Floor Flange
Or Dometic offers a mounting kit to convert to a four bolt flange.I bought my commode and flange kit from PPL trailers in Texas. Great people to work with.
SeaLand Traveler for sale at PPL - PPL Motor Homes
Hope this helps.
Argosy Heir is offline   Reply With Quote
Old 07-09-2011, 02:15 PM   #4
davidz71's Avatar
1986 25' Sovereign
The flange lifts slightly off the floor but will not twist off if threaded or worse, cemented to the black pipe going to the black water tank. I'm not taking a chance of making things worse and costing me big bucks. I will order the adapter that comes with a white ring and just use the ring to prevent the toilet from rocking. It looks like what I have now is a universal adapter without a ring for support.
Craig
AIR #0078
3.73 rear end
Old 07-22-2011, 09:22 AM   #5
TexasAir67's Avatar
1967 17' Caravel
Lufkin , Texas
Hi, I am a new owner of a 1967 Caravel and have been doing lots of restoration work!! I have the trailer nearly gutted completely, but the bathroom is holding me up. I have removed the toilet, but cannot seem to get the flange off. This flange is attached tightly to the fiberglass bathroom piece, which I want to keep in safe condition. There is nothing wrong with the fiberglass, I just want to remove the old holding tank as well as see if there is any floor damage under the shower drain. Does anyone know of a way to remove the flange from the fiberglass without messing it up?!? Thanks for your time and help, this site is AWESOME!!
TexasAir67 is offline   Reply With Quote
Old 07-22-2011, 10:18 AM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I know that on my 68' is was glued to the floor and the black tank. I don't think this was factory but a PO. can you see any sign of glue?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-22-2011, 11:20 AM   #7
TexasAir67's Avatar
1967 17' Caravel
Lufkin , Texas
Hmm, I can get a crowbar end underneath it around most of it. However, I don't want to try to pry it up in fear that it will crack the fiberglass and cause an even bigger issue. I am going to try unscrewing it and see if that might be the case. There was so much acid powder when I removed the toilet that I didn't think of many things to try. Thanks for the info, I'll give it an even closer look the next time I work on it. There is so much information on this forum it is unreal I can only work on it in spurts since it's located at my fiances house and I work a lot...
Old 07-22-2011, 11:22 AM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Some screw on and require a screwdriver and hammer to get it started.
Garry
Old 07-22-2011, 11:25 AM   #9
TexasAir67's Avatar
1967 17' Caravel
Lufkin , Texas
Thanks Gary, I will try that first!!
Old 07-22-2011, 12:04 PM   #10
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The flange on my 68 screwed it. I had to cut a little slot in the outside edge with a dremel tool for the screw driver to get a "bite" on the edge. Then tapped it with a hammer and It finally came loose and unscrewed. The other option is to use a dremel with a cut off wheel and cut the flange but you would destroy the flange and you most likely can reuse it if you are careful unscrewing it. There should be a straight threaded nipple between the bottom of the flange and the top of the black tank. The top of the black tank is threaded as is the flange. But, if some PO has worked on it there is no telling how it is attached.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
Old 07-22-2011, 03:22 PM   #11
davidz71's Avatar
1986 25' Sovereign
The Sealand Universal adapter with ring came in last week. It requires drilling eight 1/8" holes through the mount already there. It wasn't hard to do so and the new screws went into the mount or underlying floor with ease. It also required a 1/8" bead of silicone before the screws were put in and tightened. The ring fit around the mount and the toilet was then placed into position for bolting. I had a little trouble with the water supply line bolting to the toilet but finally got it squared away.
Craig
AIR #0078
3.73 rear end
Old 10-15-2011, 11:43 AM   #12
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
toilet flange
Craig
have you had any leak issues since you installed your toilet?
I need to go from 4 bolt to 2 and have been told the sealand adapter will leak,and I should buy a 4 bolt toilet.(I already have my new 2 bolt dometic 310 I was hoping to install)
thanks !
mark
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Old 12-10-2011, 06:22 AM   #13
1967 22' Safari
Las Vegas , Nevada
Anyone know if I can get a flange that has more threads on it to lift the toilet off the floor a little more? I am putting a wood floor in my bathroom and cant seem to find an extended flange. It is going into a 67 safari. The one I have has threads but not long enough. Could I use a threaded to slip piece to go into the black tank and then slip the toilet fittling onto that? I know that there are couplers for the threaded to slip toilet flanges but the ones I have seen make the toilet to hight off the floor. I need to get about another 3/8 to 1/2 inch of thread to do the trick.
thanks
tlw12 is offline   Reply With Quote
Old 12-10-2011, 08:05 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I replaced the 1/4" plywood with 3/4" when remodeling the bath in the Argosy. I installed a new toilet flange and had no problems with the additional 1/2" of material on the floor. I think I still have the receipt for the flange I bought. If you have not resolved the problem and need the info send me a PM. I don't think any kind of slip flange will work due to the sloshing in the tank while in motion.
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
Closet flange and new cork floor. desertair27 Sinks, Showers & Toilets 3 06-17-2011 04:10 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
