Old 05-01-2014, 01:11 AM   #1
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Compression fittings & road vibration
I replaced the original 1977 Moen kitchen faucet with a new faucet. The original faucet had copper pipes that were soldered to the original 3/8 copper tubing. Because it was all copper, it was pretty solid and needed no support brackets. The new faucet has flexible tubes that screw in to compression fittings. I cut the copper tubing and installed 2 compression fittings. I curled up the flexible inlet hoses and connected everything and there are no leaks. However, I'm wondering if road vibration is going to be a problem down the road. I'm thinking of purchasing some strapping and screwing it into the underside of the counter and using it to support the two 3/8 copper pipes with rubber to prevent rubbing against the pipes. What do you suggest?
4RXLA is offline   Reply With Quote
Old 05-01-2014, 04:34 AM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I think that strapping the rigid copper is a good idea. Not so much for road vibration but more so for movement (flexing beyond vibration). This stress on the soldered joints could weaken them.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 05-01-2014, 05:00 AM   #3
r carl's Avatar
Lin , Ne
Can zip ties be used?
Old 05-01-2014, 08:05 AM   #4
4RXLA's Avatar
Images: 33
I could probably use zip ties to secure the coiled hoses to the sink drain pipes as they are coiled in between the 2 sink drains and are resting on the trap.
Old 05-01-2014, 10:42 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I ended up installing a wood brace and neoprene cushioned clamps to keep the copper in place at the transition point.
Old 05-01-2014, 11:40 AM   #6
2013 20' Flying Cloud
Cream Ridge , New Jersey
Anything that can vibrate, rub or move in any way will eventually cause you problems. It may be a little more work to secure all pipes, wires etc but well worth it in the long run
Joe Palmieri is offline   Reply With Quote
Old 05-03-2014, 05:25 PM   #7
4RXLA's Avatar
Images: 33
I secured the piping to the underside of the kitchen counter and the connections are now vibration free.Click image for larger version
Name:	ImageUploadedByAirstream Forums1399159463.682277.jpg
ID:	211153Click image for larger version
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Air compression ericjan2 Classic Motorhomes 8 03-13-2013 10:47 AM
soldered copper vs. compression fittings Globie64 Fresh Water Systems 6 11-18-2009 11:25 AM
PEX compression ring differences? Moonshot Fresh Water Systems 7 09-28-2007 08:59 AM
1/4" Compression fitting for air suspension line philippes General Motorhome Topics 4 03-17-2007 08:51 PM
