Old 06-05-2013, 10:28 AM   #15
1977 21' Globetrotter
Davis , California
If you are able to find a similar faucet model online, check the manual. Usually there is a retaining ring, such as discussed above. It has the stops that only allow the faucet handle/cartridge assembly to move left/right a certain amount. Once that ring is removed, you simply rotate the cartridge 180 degrees, which reverses the mixing. Problem solved. If you're uncomfortable doing this, call a plumber, describe your problem and they should be able to service the valve for you in a couple of minutes.
flyflinger is offline   Reply With Quote
Old 06-05-2013, 10:29 AM   #16
Davis , California
oops... missed the post with the resolution in it.. my bad.... Glad it worked out.
