Old 06-17-2011, 10:06 AM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Closet flange and new cork floor.
I just installed cork flooring in our 77 Sovereign and now I'm trying to figure out how to install the closet flange.I've been reading up on it how some are cutting the flooring so the toilet sits on the plywood flooring instead of new flooring so the seal makes good contact with toilet but then you have to cut a hole for flush pedal which I don't like.I think I have enough flex in the black tank to install the original closet flange on top on new flooring even though it's not quite a 1/2 thicker.Any thoughts on this???Also any idea what kind of sealant should be used on the threads of the closet flange to tank?
Mike
desertair27 is offline   Reply With Quote
Old 06-17-2011, 10:43 AM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Desertair,
I think you can/should remove the toilet flange completely, cut a hole in the cork to match the original hole in the sub floor. The cork should not add too much thickness to the depth of flange you'll need. You should be able to reuse the old flange. If you need a taller/deeper flange, you can get them at any large RV place. I used regular pipe thread sealant on the threads of the flange. Here is a pic of Abby's closet flange.
Lance
Top is offline   Reply With Quote
Old 06-17-2011, 03:07 PM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for your advice Top.
I have to admit that I am really impressed with the quality of work you have done on Abby.The floor and Stainless support under the flange have the look like no other.Great craftsmanship.
Old 06-17-2011, 04:10 PM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Desertair. I appreciate your kind words. Post some pics of the cork floor when you are finished please.
Lance
