Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-28-2010, 10:00 PM   #1
1971 27' Overlander
Los angeles , California
Clearing clogged gray water system?
Hello,
I have a 1971 27' Overlander with a plugged Gray Water system. The sink and shower in the bathroom will not drain. I've just purchased this trailer and am new to the Airstream world - would appreciate any advice on how to safely unclog the plumbing. I do not see any clean outs built into the system. The gray water valve works and the water has drained out, but I can't get the sink and shower to drain into the tank.
Thanks in advance.
ds
dsafian is offline   Reply With Quote
Old 05-28-2010, 10:05 PM   #2
Originally Posted by dsafian View Post
Hello,
Thanks in advance.
ds
You can try reverse flushing the gray water drain lines.
Force water from a hose into the gray water outlet at the "collector", which is the white colored part of the sewer outlet.
I am not aware however, of how a gray water drain could possibly be stopped up in your Airstream.
Black water blocked yes, but gray water, no.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-28-2010, 10:38 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
We had a similar thing in our moho. It was just crud in the P-traps. Used a small bottle brush on a flexible cable. Cleaned up in a few minutes and they drain fine.
Good luck, Dan
Old 05-28-2010, 10:40 PM   #4
1971 27' Overlander
Honestly, I'm not sure either - just don't have experience with the system.
I've dealt with the Black water system and that was a nightmare, but the tank is clear now. As I mentioned, the sink and tub in the bathroom will not drain completely. But the water from the kitchen seems to drain and I can empty the gray water tank without the water going down in the bathroom. I can only surmise that the lines are somehow blocked. Are you talking about the water spigot at the back of the trailer next to the black tank outlet - is that where I'd attach a hose and "back" flush the system?
thanks.
ds
Old 05-28-2010, 10:43 PM   #5
Retired.
. , At Large
Hello,
Thanks in advance.
ds
1971 Airstreams did not come from the factory with grey tanks of any kind. Maybe there is no tank, and the sewer cap is holding the grey water in the drain lines. Removing the sewer cap will show if this is the problem, when the grey water pours out onto the ground.
Old 05-28-2010, 11:18 PM   #6
1971 27' Overlander
Ah, Ok - this makes sense to me. So there is no tank the lines just drain out - got it. Is there a way to access the P-traps or is it just that I have to snake something down inside?
thanks for the beta.
ds
Old 05-29-2010, 05:39 AM   #7
Retired.
. , At Large
ds
You can access the trap in the bathroom sink by opening the rear compartment hatch, and looking up inside it. you'll see it there at the bottom of the sink. Getting to the tub trap is something of a PITA, and I wouldn't recommend it unless you are sure you are having problems.
Old 05-29-2010, 06:18 AM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Remove the cap
No Gray tank here. The water is draining from the sink, filling the drain line to that cap. Your probably lucky if there is not water coming up thru the shower drain from that capped line. Your cap should have a hose connection on it (with a screw on cap) to be used to drain the gray water away from the camper.
Old 05-29-2010, 09:28 AM   #9
Ottawa , ON
If you have children, inspect the two bathroom drains for small objects forced into the drain.
With kids, you Just Never Know...
Black water rinse clogged! Resorts Waste Systems, Tanks & Totes 16 04-28-2021 11:48 AM
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
Where does my gray water go? Finn M Waste Systems, Tanks & Totes 3 05-07-2009 08:23 AM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
And gray water came shooting out.... Tin Can Crabs Waste Systems, Tanks & Totes 9 07-07-2004 10:48 AM
