Old 06-30-2003, 07:40 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Cleaning bathroom & toilet
What is safe to use on the sink and toilet in my '71 Safari.
The sink and counter is that molded fiberglass stuff.
The toilet says to use only special cleaners and I assume you don't use bleach.
Just wondering what everyone else uses?
-Tim
theVAP - Airstream Podcast
Old 06-30-2003, 07:51 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Safari Tim!
For light soiling, I utilize Murphy's Oil Soap as it is kind to all surfaces and leaves a clean, fresh scent. For heavier soiling on both the fiberglass in the shower/tub and on the ABS in the vanity and toilet, I use a product called The Works that I purchase at Wal Mart - - - it is a special clearner designed for fiberglass and plastic that is non-abrasive and cleans effectively.
Kevin
Kevin D. Allen
AIR #827
Old 06-30-2003, 08:23 PM   #3
sjptak's Avatar
Kevin,
That sounds soooo professional, I don't know what to say.
I discovered Murphy's Oil Soap years back and love the stuff. Its not harsh, not abrasive, works great for really dirty laundry and I can't say enough good about it. Great Stuff for almost anything. Haven't tried it on the dog yet..........
Stan and the Lou
Together Forever
BTW, that's MaryLou
sjptak is offline   Reply With Quote
Old 06-30-2003, 08:33 PM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Our's had stains that no cleaner would get out so when my wife wasn't looking I used 600 grit sand paper, sanded out the stains then waxed it with fiberglass wax.
Hope you don't have to go to this extreem but I did solve the problem.
Garry
Old 07-01-2003, 12:05 PM   #5
74Tradewind's Avatar
Great Idea
Never thought of using the Oil Soap on the fiberglass things. I will try it today as we are going to Lake Tahoe next week.
We do use spray on silicone in the toilet bowl before each trip while it is dry. The plastic is a little rough and this makes it easier to clean. It also works in the sink and on top of the counter. I don't recommend it for the shower though.
Ciao, Brian
www.ISellThousandOaks.com
74Tradewind is offline   Reply With Quote
Old 07-23-2013, 10:00 PM   #6
2009 27' FB Flying Cloud
Chambersburg , Pennsylvania
I have read many of the threads and I still have not found an answer to my dilemma in cleaning the poopee nubs (I know, sounds disgusting to me too) from my toilet bowl without using an abrasive or chemical product. We have tried everything but cannot remove those little dots that accumulate in the bowl. We've even tried a plastic spoon as a scraper.
Any helpful solutions would be appreciated.
Dusty-B is offline   Reply With Quote
Old 07-23-2013, 10:15 PM   #7
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
Sometimes prevention is the best cure....
Before using the thetford for it's intended purpose, sometimes it is helpful to lay a few folds of paper in the landing zone.
Then, when the plunger is depressed, theoretically everything is flushed down the hole.
Jim Lee is offline   Reply With Quote
Old 07-24-2013, 04:41 AM   #8
1971 29' Ambassador
Leonardtown , Maryland
ZUD.... it is abrasive but it works.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 07-24-2013, 05:20 AM   #9
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
Garry
haha love that Garry...sometimes I wish the elves would do tricks like that behind my back. I wouldn't be able to stand knowing it was being done but what I don't know won't hurt me so I approve, wholeheartedly!
As to the er'ahem 'nubs' try bon ami, it's non abrasive but works as if it is.
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 07-24-2013, 05:38 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Easy-off fume-free oven cleaner might work, if you drain the bowl first (turn off the water, then flush). If it will clean cooked-on residue from a grill, it should do for your toilet bowl, too. Best of all, spray it on, go have a beer while it does its thing, then come back and scrub lightly with a regular toilet brush, then turn the water back on and rinse. Simple.
Easy-off is my default cleaner for just about anything that otherwise would require hard scrubbing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-01-2013, 06:49 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Have you tried hydrogen peroxide? Put a dab on a one spot using a q-tip... It removes a lot of organics.
Also, strange, yet a bit of Dawn on a dryer sheet and moisten a little. Rub spot. It removes "love bugs" remains very nicely.
Peace and Blessings..
Channing
WBCCI# 30676
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
? Cleaning Toilet ? srae Sinks, Showers & Toilets 8 08-14-2003 01:30 PM
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
