Old 03-27-2014, 09:13 AM   #57
Razinni's Avatar
1977 31' Sovereign
Atlanta , Georgia
finding weights is tricky but does anyone have a basic idea of a lightweight RV toilet vs china? Is it 10 pounds more?
RAz
"The road goes on forever and the party never ends" - R.E.Keen
Razinni is offline   Reply With Quote
Old 03-27-2014, 09:18 AM   #58
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
And the answer is....
http://www.dometic.com/a5147e5a-ba32...58126a72.fodoc
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-05-2014, 09:21 AM   #59
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Has anyone changed out a toilet in a 2012 25 foot AS. It appears that ours spring a leak over the winter and needs to be replaced. I am looking at the one that is higher in height then the one in there and is wondering if anyone has one.
thanks
John
urnmor is offline   Reply With Quote
Old 04-05-2014, 11:37 AM   #60
urnmor's Avatar
Berlin , Maryland
Please disregard I took off the water valve and it looks like that is the problem so I will not need to replace the bowl, at least for now.
Old 04-05-2014, 12:31 PM   #61
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Those valves seem to be the most likely things to get damaged in the winter. I had one crack one winter. Ever since them I have been extremely diligent about getting the water out of there when I winterize.
Ken
Old 04-05-2014, 08:08 PM   #62
urnmor's Avatar
Berlin , Maryland
Ken
Do you do anytning special to remove the water from that valve.
John
Old 04-05-2014, 08:38 PM   #63
Ag&Au's Avatar
Ken
John
I winterize by very thoroughly blowing the lines clear with my compressor. I only use antifreeze in the sink etc, traps. The only thing special I do is go through the whole sequence as outlined in my manual at least three times. I continue with each faucet and valve until not even a hint of vapor is exiting. In the case of the toilet valve, I hold the toilet in the flush position until the only H2O escaping is produced in my compressor.http://www.airforums.com/forums/images/smilies/wink.gif
The one plus about the toilet valve is the fact that compared to most other things than can be damaged by ice, it is relatively east to replace.
Ken
Old 04-06-2014, 07:15 AM   #64
urnmor's Avatar
Berlin , Maryland
Ken Thanks
I thought I had blown all of the water out of the system but apparently not as the valve does have a split in it. Maybe next year I just might take it out for the season or disconnect the lines to it.
John
1978 ambassador toilet leak mohrjr Sinks, Showers & Toilets 4 05-20-2011 09:38 PM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
China toilet and rear end separation nukefamily Sinks, Showers & Toilets 0 02-01-2011 09:37 AM
