Old 03-13-2014, 04:03 PM   #1
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Cheap Shower Door - I Gave Up...
As noted by other poster's who have an International, the shower door has a serious design flaw. In order for it to operate smoothly, it "hangs" from a very small bolt that screws into the upper header of the door. When this breaks, the door drops onto the sill, breaks the plastic sweep and makes it very difficult to open and close the door. So, today I investigated. The tiny little bolt (pot metal) had sheared. IMHO, the door is much too heavy to be suspended from a bolt that's this fragile. As I looked at the rest of the install, I decided to rip the whole door out and put in something more substantial. (I also saw evidence of a "gorilla" attack where the fiberglass was shattered in 4 places by someone who had too much torque dialed into his cordless screwdriver). This particular door (Sterling) pivots on two very solid bolts (1/4") -- steel. The job took a couple of hours as I had to do a bit of carpentry work as the new door is 65 1/2" high and the old one was 64". Took me a couple of hours, but this is a much higher quality door and it is NOT suspended by a cheap, teeny, tiny bolt.
ID:	207364   Click image for larger version
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
2011 International 25FB -- Freeze Damage to Shower Heads and Galley Faucets NJ2Cali Plumbing - Systems & Fixtures 10 02-01-2012 02:09 PM
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 04:43 PM
Shower Door Replacement Kamiak General Interior Topics 1 12-05-2011 12:56 PM
Shower Head Height - 67' GT star kitty Sinks, Showers & Toilets 0 08-31-2011 12:35 PM
